Question about Dryers
The dryer runs but there is no heat ,igniter glows, but i do not know if it is on long enough or if it get hot enough.
  • 494 Answers
This is usually a symptom of a lint clogged vent or restricted air flow through an expandable, plastic or foil vent tube behind the dryer that is squished. First check your lint filter and clean it. With the filter removed, check the filter reservoir and see if there is a lot of lint that needs to be cleaned out. If not, then you will more than likely need to pull the dryer out to check the vent for blockage. Unplug the dryer and remove the vent from the back of the dryer. Using a flashlight, clean out or vacuumthe dryer runs but there is no heat ,igniter - 2_bing.gif out the excess lint. Do the same for the vent tube you disconnected. Also check outside at the vent cap to make sure it is not blocked there and that good air flow allows the vent flap to open when the dryer is running. You can check this after you reassemble the vent inside and fire it off. Hope this helps solve your problem. Douglas
Posted on Jun 03, 2010
5 Suggested Answers
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
ginko
  • 19396 Answers
SOURCE: Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on Oct 04, 2008
  • 36 Answers
SOURCE: Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Posted on Jan 02, 2009
  • 77 Answers
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Posted on Apr 18, 2009
It dries great and doesn't continue to run, however, on/off light still stays on even after it's done.
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Jan 25, 2016 | Amana NED7200TW Electric Dryer
Have samsong front loader dryer running for short periods of time and it is shutdown and will not start for short periods of time
Bad motor windings
Thermal Fuse
Air Flow and Heat
Warning
Jan 19, 2016 | Dryers
I have gas GE Dryer Model DPSR483GA2WW that will not heat. Replaced selnoides and igniter. No difference. Can't see if igniter is glowing because view is from bottom of machine. Checked all thermo
Thermal Fuse
Air Flow and Heat
Warning
Dec 21, 2014 | GE Dryers
Neptune gas dryer runs but no heat
Thermal Fuse
Air Flow and Heat
Warning
Oct 17, 2014 | Dryers
Gas dryer heats up runs about 3-5 minutes then quits. Have cleaned all filters, exhaust and sensor with problem continuing
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!!
Oct 12, 2014 | Bosch Nexxt 500 Plus Dryer
GE Spacemaker Dryer DPXH46 (gas) runs and blows but stopped heating. Gas supply is good. How do I troubleshoot the igniter?
Thermal Fuse
Air Flow and Heat
Warning
Oct 05, 2014 | Dryers
What is wrong with a whirlpool gas dryer model #LGR4634EQ2 that won't heat and the timer runs down to near the end but not far enough to shut off?
Thermal Fuse
Air Flow and Heat
Warning
Oct 04, 2014 | Dryers
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
Aug 30, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
Maytag dryer runs but doesn't heat up
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
