Question about Gli Pro XA2200 Amplifier
Unit does not power on any more
GLi XA-2200 rack mount power amp. Used for practice 3 times per week in a live band. Never over heated or used with any other cable than Speakons (which work great with other amps).
Ran great for 8 months then left "A" side started fading. LED backlight failure on left channel analog needle. 10 months and left side faded completely. After 12 months the right "B" side started fading as well., but LED backlight still works Amp powered up, just gave less and less power to the speakers. Then it stopped about 14 months.
Now it simply powers on, power light switch illuminates, but both outputs send a spike that clips my speakers roughly every 3 seconds at regular intervals.
Any ideas what to test and replace?
2 Suggested Answers
  • 24 Answers
SOURCE: How much Rms power does the a-6300 put out per channel
The amp is rated at 120wpc on various websites but I suspect that number is too high since the amp weighs only 15lbs. The 400 watt spec is power consumed - not speaker/RMS power.
As for blowing out your speakers, that far more likely to happen with a low powered or cheap amplifier like the GLI A-6300. A low powered amp will quickly burn out a speaker if driven too hard. If you want to protect your speakers from damage, either keep the volume at a reasonable level or buy a bigger amp.
Posted on Dec 28, 2008
Technical support for gli pro rcx5000u hibryd amplifiers
There is an email address here...
Jul 04, 2014 | Nil GLI Pro RCX 5000 2000W Rack Mount 4...
I've changed my engine mounts 3 times on my 2004 A4 cabreolet and they fail within miles(start to vibrate & then within a week, severe knocking) the 2nd time, also changed the ****** mount, 3r
Engine mounts do not go bad in five miles. Sounds like you're treating a symptom and not the cause of a more serious issue. Are you sure all cylinders are firing correctly? That the severe knocking is not coming from your engine internals? Have you checked the steel around the engine mounting points for cracks or other damage? And just in case, if the mounts you are using are poly, are you lubing them before installation?
Aug 31, 2012 | 2005 Audi A4
Cost of running window a/c unit
the total power used is 750 watts so multiply that by the number of hours in use say 60 hours a week
so 60 X 750 = 42000 or 4.2 kw hours X 4 cents per kw/h =418 cents or $4.18 per week X 4 weeks =$16.72
if you are a college student talk with a maths teacher and see if what I an calculating is correct but there is no way that the ac unit will cost $150.00 a month to run
you have to be careful here as to charge you for an ac unit , it has to be on a separate meter and I suspect that he is trying to get you to subsidise his electricity account outside of the rent costs which include power for the stove and hot water
as an example we run a 2.7kw ac for 12 hours or longer and the total household bill at 21 cents / kw hour ( we live in a country where the power is a major component of the household budget) is around $360.00 per month so I think that by comparison he is trying to rip you off
seek legal advice on the subject and if the rent payment includes electricity usage then he will need a separate meter to charge for the ac unit
Jun 16, 2017 | Haier Heating & Cooling
Leaking rack and pinion steering unit in a 2002 infiniti i35. How do you repair and what is the estimated cost?
The only way to repair a leaking rack and pinion is to replace the rack and pinion with either a new or remanufactured unit. (Nobody sells rebuild kits for them like they used to several years ago.)
AutoZone lists a remanufactured unit for $452.99 plus a $115.00 core charge. Click HERE for more information.
If you are having a professional shop do the job, they will most likely charge you the standard labor time multiplied by the shop labor rate + alignment charges. This can vary considerably depending on the area where you live and what shop you take it to. The standard labor time to perform rack and pinion replacement on your vehicle is 5.5 hours. (Does not include alignment)
The labor rate in my area averages about $95 per hour. A wheel alignment can be done for about $70.
The total job would run $1045.99 + taxes and charges for shop supplies, which would put it right in the neighborhood of $1100.00.
Jun 17, 2011 | Infiniti I35 Cars & Trucks
How do you install a rack n pinion on a 1999 grand am
I suggest a manual from your local auto parts store, but I can give you the basics.
You will need the car raised for clearance underneath as you will be removing the following: Tie rod ends, power steering hoses to the rack itself, the rack mounting bolts & your wheels on both sides to provide clearance. The steering column also has to be disconnected from the rack unit, from underneath the car. (sometimes you need to loosen the shaft inside the drivers compartment to allow the mating part to slide & be removed. You should be able to take the rack out through the wheel well.
You'll nee to swap parts from the old rack to the new rack that are being reused, be sure to measure your distance from tip to tip of your rack unit and use that measurement to assemble the parts and eliminate the need for front end alignment once completed.
Reinstall all of your parts and secure properly. keep the front end raised and supported & you will need to bleed the rack unit.
To do this, fill the P.S. system, not overfull, then start the vehicle and slowly turn the wheel from the far left turn to a far right turn about 3 or 4 times. Stop & check fluid each time. Do not hold the steering wheel to the far right or left as that increases the pressure on the system to an unsafe level and doesn't help the vehicle or the process of bleeding the brakes.
You should be ready to go, check & refill the fluid in the PS system.
Feb 15, 2010 | 1999 Pontiac Grand Am GT
Powers up and shapes the sound but no boost?
the power source you are using is too low you need power source that has a 20-25 amp out put dc find a bigger power source and not the ampriage
Mar 27, 2009 | Pyramid 903G 10-Band Car Equalizer
Crown amp xs900 will not reset
naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
  • 2-ohm dual (per channel) : 1200W
  • 4-ohm dual (per channel) : 900W
  • 8-ohm dual (per channel) : 600W
  • 4-ohm Bridge : 2500W
  • 8-ohm Bridge 2100W
  • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
  • Housed in a rugged, all-steel 2U chassis
  • Microprocessor-controlled protection system.
  • Flow-through ventilation from front to back.
  • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
  • EIA Standard 19-inch rack mount width
  • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
  • XLR-¼" combo connectors: One per channel
  • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
  • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
  • Balanced XLR connectors (2-channel models only)
  • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
  • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
  • 4-Pole Speakon output connector (2-channel models only)
  • Accepts a 4-pole Speakon connector.
Dec 31, 2008 | Crown XS900 2-Channel Amplifier
Gli Pro XA2200 Amplifier Logo
Top Gli Pro Audio Players & Recorders Experts
Are you a Gli Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
