Question about Weber Genesis Silver A Grill
Grill heats up slowly and never gets to top heat.
--can't get the heat up to 550 degrees- the grill is about 7 years old. We just got it hitched up for this year--did not have trouble last year--have we done something wrong?--Nancy Peterson
  • 3,740 Answers
Hi Nancy and welcome to FixYa. I am Kelly.
After a BBQ has sat for a while there are things that need to be checked.
1. Remove the burner(s) and check for anything in the gas path area. Use a BBQ stick if necessary to remove any cobwebs.
2. While the burner(s) is/are removed check the burner orifices for any build up and wipe it clean with a dry cloth.
3. There is a possibility after 7 years that the regulator has started the corrosion process and the diaphram is sticking not allowing full pressure to the gas control valves. If you suspect an LPG reguator problem just replace it. After 7 years it is time anyway.
That should get your temps back to normal again. If not then you may have to disassemble the gas valves and clean them. Carb cleaner or engine degreaser works great on the greese build up. Engine degreaser however will discolor things if you do not rinse it off quite well right away. Same thing goes for oven cleaner.
Thanks for using FixYa.
Kelly
Posted on Jun 03, 2010
Won't heat up above 200 degrees.
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Mar 26, 2014 | Broilmaster Premium P3 Grill
Periodicly I won'y be able to get the grill temp to over 200 degrees. sometimes it is ok and can reach as high as 500 degrees other times it will just not generate enough heat to grill.This is a five...
zonfish - if you're tuning the gas tank off at each use, as you should. The problem lies in your grill's gas regulator, but it also is not a big deal and is easily solved.
Whenever, you open the tank valve, do it VERY, VERY, SLOWLY (Slow Motion, slow), until it is fully open. Then light the burners.
What happens is this, LP Gas Grill Tanks are now equipped with an Overfill Protection Device ("OPD"). And often time, when you turn the valve on like you would normally do, the OPD Valve sends a hot load of gas to your grill's regulator and partially locks it up or locks up entirely. Therefore, the burners are not getting enough gas to heat the unit up to 500 degrees. Opening the valve very, very, slowly, overcomes this problem.
I hope this helped you and Happy Grilling.
Jun 20, 2011 | Brinkmann 810-2300-B Grill
One day it will not heat up over 300 degrees and the next day it will heat up over 400 degrees without any problem. I dont know if it is the gas tank or the grill. Nothing on the grill appears to be...
More than likely, it's the OPD valve on the LP G tank. When it won't heat up above 300 degrees is after the tank was turned OFF & then turned back ON? If that is the case, disconnect the gas line from the tank, wait 5 minutes, reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY. This will keep the tank valve from locking up the grill regulator and thereby, gas will get fully to each burner. If this doen't correct the problem the first time, repeat the above procedure.
That should solve your problem
Mar 06, 2011 | Fiesta Blue Ember Gas Grill
How can i sear with my weber gas grill?
When you sear meat all you are doing is cooking the outside at high temperature so a caramelized crust forms. To do this on a gas grill turn all of your burners on high, close the top and let the grill get very hot, I usually shoot for around 400 to 450 degrees. When you put the meat on the grill do it fast, directly over the heat source and close the top to keep the heat up. You'll have to experiment but usually about a minute and a half to two minutes per side is all it takes. You want the meat to be thoroughly browned on the outside. Now turn the heat down or off on one side if your grill is set up for that, flip the meat and cook it slowly on the side of the grill that's turned off or over indirect heat to your desired done-ness. This will depend totally on the thickness of your meat, again experiment. Another important step is to let the meat stand for five to ten minutes after taking it off the grill. This keeps all the juices from running out of the meat the first time you cut into it and ending up on your plate.
Jan 17, 2011 | Garden
Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
May 22, 2009 | Weber Genesis Silver A Grill
2 year old Charmglow 4 burner grill barely heating to 200 on high
check the burners for debris such as..... a mud dobbers nest/ spiders.
Mar 22, 2009 | Brinkmann Charmglow Stainless Steel LP...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Low output
The grill is not staying lite and not heating up like it should.
Jul 03, 2008 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Weber Genesis Silver A Grill Logo
287 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
