Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Power supply I have the same problem but the power supply part # is cofusing and nowhere on the net is a picture of it. Service shop told me the part cost over $200 but some part dealers are telling me about part that cost as little as $65. Can you help me with the right part #? I wonder if the PS will burn up again.  One part # is 310432836301  PWR SUPL A other 310432836211 for $261.62 Thank you
  • 3 more comments
  • Jerry Krauz Apr 29, 2008
    Thanks for the part number.  Just before you put it here, one supplier sent me a wrong part. Same TV and they come with a wrong power supply.
    I noticed where the little sticker on the wrong part is, so I doublechecked your and viola, it's there. Pretty hard to see. What's confusing is, that the circuit board has a similar, bigger number etched in but it's not the right one.
      One more thing. Philips was rude and no help at all. So you can guess what my next HDTV will be.  Not Philips!
  • Jerry Krauz Apr 30, 2008
    I'll tell you next week if the power supply was the problem.
    Thanx again.
  • Jerry Krauz May 07, 2008
    "3104 328 38621 Is the part number for the supply."
    Thanks. It came in and the problem is gone. Small resistor was blown a Philips is using a bigger one now.
  • dominios_mon
    dominios_mon Sep 16, 2012
    how can i get the complet board
  • Jerry Krauz Sep 17, 2012
    E-bay http://www.ebay.com/itm/Philips-3104-328...
    Scholar:
  • 72 Answers
3104 328 38621 Is the part number for the supply. I repair plasma and lcds tvs this is the number that i use were i work . If u go to partstore.com u can find it there for 114.32 hope this helps
Posted on Apr 15, 2008
  • 1 more comment
  • James Peters
    James Peters Apr 29, 2008
    Pretty much the big number is etched on a circuit board is just a generic number for the pcb board before any components are added. If u are looking or a part number look for the 12NC. I can't say too much about philips being rude too you. But im glad i was able to help out.
  • James Peters
    James Peters May 07, 2008
    Original 470 Ohm resistor was a I watt. Replacement is a 2 watt. Glad I could help.
  • dominios_mon
    james i thank U i have on samaung lcd with negetive picture
I have a hitachi p50h401 i was told it needed a power supply n 10 amp fuse i have replaced the power supply but not sure where the fuse is located. so i still have no power. can you help please?
Hello
Download the service manual to your Hitachi P50H401, from net. you can't find it for a free download. most of the service manual to Hitachi will be a paid download from such sites.
Service maual will have all the details about circuits and printed circuit board, and part loacations. Ok.
http://www.dataentryjobs.us/67948.html
Feb 01, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Sharp lc-26d40u No picture
I have a Sharp Aquos LC-40E77UN with the same issue, and have tracked down a single burned capacitor at C7816 on the power supply board, and am looking for info on the capacitor in order to replace it. (Power supply: RDENCA354WJQZ / Delta DPS 208BPA). - Any help with a schematic would be appreciated!)
Since you say the picture went out, it is possible that you might have the same problem, Bad/failed/leaking capacitors are, unfortunately, quite common in electronics. There are volumes of info available on the subject.
Replacement power boards can also be purchased. One for my TV runs about $60 to $120 depending on used or new. Since I was able to see a good picture on mine for a few seconds, despite the burnt out capacitor, I'm opting to try and find/replace the cap myself (using the proper safety procedures), or at worst, have a repair done to the power supply.
Backlights should typically last around 60,000 hours.
Aug 29, 2009 | Sharp LC-26D40U 26 in. LCD HDTV
1999 zienth projection tv that has no picture
I have a Zenith (10 years old) not sure if is the same style; but I had the same problem. After being told to toss it, another shop "repaired power supply deflection parts and labor, part and major technical preform". Now have perfect picture and tv is like new. Cost was $295 for parts, labor and service call. It was in shop for a week. Hope this helps. Good luck
Mar 11, 2009 | Zenith IQB55M90W 55" Rear Projection...
No picture
Had the same problem, Insignia 32 would click on then go off. About 6 months ago I found (somewhere on the net) a guy who explained that he changed blown capacitors. As I recall he even posted a picture. I found the blown capacitors and replaced them with larger capacitors (less than $20) problem solved...
But now my screen image is showing only half a picture and is pulsing on a off.
I think I'm going to make a Wii commercial......GL
Oct 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Service shop
The power supply can be repair, but many service techs rather not to, because they are switching power supplies and it can be a bit more difficult to fix them.
Many power supply components failed because they are expose to high heat generated internally when the TV is working, if the capacitors are working with temperatures of 170-185 degrees fahrenheit, their life expectancy is about 1000 to 1500 hours.
Jul 08, 2008 | Televison & Video
Service shop
Is the power supply completely dead ? If so with this model of power supply its very common for the resistor 3318 on power supply to go out. Causing the power supply to completely die. Take out the resistor 3318 its a 470 Ohm 1W resistor. check it if it doesn't read around 430-530 Ohm Its gonna be bad ( most likely ith will read in the mega ohms. Replace with a 470 Ohm 2 W resistor. Also check power supply for cracks
Apr 29, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture problem
It's not an adjustable problem and not all that easy to guess at either. Power supply is a usual suspect and my best suggestion would be to take it to a reliable shop for an estimate.
Bill
Mar 13, 2008 | Sansui DTV3200 32" TV
Westinghouse LVM-37w1 Goes immediately into standby mode
Power suplly. In my case I should have done research on a lot of things before purchase - westinghouse doe snot acknowled any power supplly uissue but they would say that, and this is a direct quote from them, "Westinghouse's failure rate is less than 2%, which is great by industry standards. Unfortunately, when you sell millions of televisions, 2% is still a lot of televisions. There have been no recalls on this model (or any of our models), but it's not surprising to find a similiar issue on more than one of millions of televisions."
In other words they calim there is nothing that is really their fault. However the first thing the repair guy said before he even looked at it was "Power supply". He opened it up and tested - power suplly. However to complicate matters more I made is huge mistake of buying into a scam offered by eCost via Service.net . A two year, 100%, in home service, warranty. Bottom line is since June 8 my Monitors has not worked and sine July 7 it has been sitting untouched, not here, but at a rprair facily over 50 miles away. As of yesterday August 7, I was told Westinghouse no longer makes or provides power supplies for this unit. On top of that the repair facility will not return it to me unless i pick it up why? Because it can't be fixed and because service.net will not pay them to return it to me.
So solution at thi point for anyone with power supply issues is to try and repiar it yourself. And then in the future never purchase anything from westinghouse again. (And if offered any sort of 100% all cost covere din home warrabnty from service.net run away screaming)
Feb 05, 2008 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Power Supply
As far as i know the power supply and the control panel come as one unit if you can send me the complete model number and the serial number i can check to see if they sell the power supply seperately and what the cost will be.
Lou Margo
Allied Electronics
loumargo@verizon.net
513 490 0759
Nov 11, 2007 | Polaroid FLM-2601 Television
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
457 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
