Question about Garden
Jun 03, 2010 - hello the mower deck is off mower when we started. The guy who took it off is gone. New guy thinks he has the 2 rear draft arms on correctly also the 2 front draft rodes are on correctly. Now the information that you sent me is not the same deck no drive cables etc. etc. We have one 8 inch by one inch tight spring left over where does it go? Also how do we tighten the belt? adjustable pulley is loose but bulted tightly. What we need to know is 1. how do we tighten the belt 2. we know deck should not be sitting on ground what do we do? Keep in mind we have no mower engagememnt drive cable or spring locking pin. Basically top of deck has 4 pulleys that feed to drive pulley on mower. We can't engage blades because belt is way to loose, plus can't move mower because deck is sitting on the ground. With deck in the up or down position. Basically we're at at loss. Jun 03, 2010 - again this is for the John Deere STX 38 1988 model with Kohler 12.5 command system. John Deere thinks the ignition module is bad so we replaced it, but can't test it until we run the mower.Jun 03, 2010 - It has a easy mower lift electric engage???? Does this mean deck raises on it's own when we go to cut grass? As you can see we are at a loss.
  • 6,993 Answers
please can you rephrase this question and go straight to the point.
I don't really understand the question.
I look forward to your reply.
Bye for now.
Posted on Jul 05, 2010
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Mower deck draft arms keep coming loose from spring pins.
put a washer between the arm and pin,use a zip tie to hold them,put them on backwards,stop hitting things that will move them.
Jun 26, 2015 | Garden
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Tractor cuts uneven, how do I correct it?.
make sure the blades are not bent , and stay the same hieight while rotating , ( do this while engine is stopped and plug disconnected your will have to physically look underneath - ie use a block and tackle to lift front end while you look physically turn them and try to make them move up and down / sideways and look for any un eveness in blade tracking
make sure the mandrell housing bearings are ok not loose
if mandrells brgs or spindles are bent they will need replacing
make spindles are not bent ?
make sure tyre pressures are 15 psi fr and 10 psi rear
make sure the the distance from floor to btm edge of r/h side of deck is the same as the l/h side adjust one or other until you have same measurement use tape measure ( this is side to side level )
then make sure you have rear edge of deck at the mid point about 5 mm higher than the front edge ( this is the rake ), adjust using the front draft arms or front lift link
make sure deck lifts evenly , you should see arms or lift links that connect to deck on l/h and r/h sides and at the front these will have some form of adjustment so deck can be levelled and rake set
if need let me know make and model and year and deck size of machine and i will try help further
cheers paul
Aug 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
STATESMAN RIDER BY MTD
Those pulleys most likely have part numbers stamped on them. If not you can take the pulleys to a lawn mower or small engine repair shop and they can match them up with pulleys they have in stock.
Jul 05, 2010 | Mtd Garden
My john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Sep 03, 2009 | John Deere &Reg Branded 27" Tractor Metal...
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
