Question about Home
Hi, I have a Triton Power shower, it has worked fine for the last few years but today the water stopped. The pump is still running but nothing is coming out. Would you have any ideas. Thanks, Gary
  • 3,740 Answers
Hi Gary, Sometimes things like pieces of worn out faucett washers get in the shower head water line and clog things up. The only alternative is to disconnect the plumbing starting from the shower head back to the wall and start removing the pieces of rubber. There could be a problem with the impeller in the power shower pump but again you would have to gain access to the pump impeller and inspect it for damage. An impeller can fail in may ways... most of the time it is either broken blades of a broken hub of the impeller. Other times the housing for the impeller can be broken and water bypasses inside of the pump vs exiting the pump.
Thanks for using FixYa.
Kelly
Posted on Jun 03, 2010
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Water flows continuosly for 1minute after switched off
You need to check all valves, one of them must be broken or too old.
Also the pressure is a little bit higher in there, but there is nothing to be afraid of.
CIAO
May 05, 2011 | Home
My triton aquasensation AS2000T power shower has stopped working. Makes noise as if motor is working but no flow. took cover off and found quite a lot of Carbon? on inside. Is this likely to be the...
I have had a similar problem which is down to the motor top bearing which has tightened up. I have recovered this 2 or 3 times now over the last couple of years by a total overhaul after strip down. By far the easiest way of solving without a total dis assembly would be a few drops of '3in1' at the very top outside of the motor assy (the black plastic looking part. Not the commutator. The motor might need to be turned back and forth a few times by hand to get the oil 'in'. It should then run freely.
Jul 03, 2010 | Home
Triton Shower is not working at all after a years great service.
FIRST TURN OFF POWER SUPPLY THEN OPEN UP THE CASE AND INSPECT THE WATER PUMP FOR ANY BUILD UP OF SCALE IF SO CLEAN WITH A GOOD SCALE REMOVER, ALSO CHECK THE PUMP IS NOT FAULTY AS THIS COULD BE THE CAUSE OF YOUR PROBLEM , ALSO CHECK FOR ANY LOOSE WIRE CONECTIONS .
Nov 11, 2009 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
339 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
