Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer LE493OXSNO will not turn on. I bought a thermal fuse. Can you tell me where the fuse is located, and how to install it?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerWhirlpool dryer LE493OXSNO will not turn on. - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turningDryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 08, 2010
Where is thermal fuse
The thermal fuse is located on the rear of the machine. Unplug the dryer, and with a 1/4 inch driver, or drill with 1/4 inch adapter, remove the 9 screws and take the back cover off. The thermal fuse that kills the dryers ability to turn on is located on the lower left side if your standing behind it. The hi-limit and temp. fuses are located on the heating element canister on the right hand side. Good luck.
Apr 28, 2012 | Whirlpool LER5636P Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Removing a part form a Whirlpool Electric Dryer
    The thermal fuse is located on the outside of the blower housing. To get access to the thermal fuse you will need to remove the back panel of your Whirlpool dryer.
    How do you check it:
    Before you do any repairs on your dryer, you will need to disconnect the dryer from the wall outlet.
    After removing the back panel, remove one wire from the Whirlpool dryer thermal fuse and take a reading between the two terminal on the thermal fuse.
    The reading should be 0 ohms, if the reading is infinity, the thermal fuse is bad and it must be replace. When you find a bad thermal fuse, you will need to replace the operating thermostat too.
    The operating thermostat opens at 155 degrees and the thermal fuse blows at 196.
    These means that operating thermostat did not open at 155 and that is why the thermal fuse failed.
    Jul 12, 2010 | Whirlpool Dryers
    Hi i have a whirlpool gas dryer LGR8648LWO and
    If your ignitor (glow bar) is glowing that indicates the thermal fuse is okay.
    With the symptoms you are describing it is acting more like an air flow issue than a component failure. Make sure your door seal is good, your venting is connected properly and try it again. I would not install the thermal fuse.
    Apr 23, 2010 | Whirlpool Dryers
    Trying to locate thermistor whirpool dryer and replace it
    Just bought a new thermistor for the Whirlpool Duet dryer and ready to install, does it has any polarity; ie. does it matter which wire goes to which side?
    Jun 16, 2009 | Whirlpool GEW9250 Electric Dryer
    Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
    check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
    Mar 08, 2009 | Whirlpool Dryers
    Whirlpool dryer LER5636JQ0 won't turn on
    The thermal fuse for your dryer is located behind the rear panel. With the rear panel removed, you can locate the thermal fuse as a small white plastic device located on the blower fan housing on the lower left-hand side (facing from the rear). A resistance reading should indicate close to a short (0 ohms). If the thermal fuse IS defective, the replacement part number is 3392519. You can find all this information at searspartsdirect.com. Just type in your model number and look under the "Bulkhead" heading on the next page. The thermal fuse is listed as item number 7. There's also helpful part locator diagrams to assist in troubleshooting. I hope you find this information helpful. If you need further assistance, please post back and let me know.
    Jun 06, 2008 | Whirlpool LER5636P Electric Dryer
    Fuse
    This electric dryer has a thermal fuse. If blown, the drum will not turn. On a gas dryer the drum will still turn but no heat. The thermal fuse is located on the blower housing. You have to remove the back panel to get at it. It will be the white fuse located right above the fixed thermostat. Two wires going to it. Catriver.
    Apr 26, 2008 | Whirlpool LER2614JQ Electric Dryer
    Whirlpool LER5636P Electric Dryer Logo
    156 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
