How do I set up a web key on my router usr 5461 wireless g max
    Scholar:
  • 50 Answers
You're going to want to navigate to the router's configuration page. The easiest way to find this, if you are running Windows, is to click the Start button, click "Run", and type in "cmd".
You'll see a black window. Once in there, type in "ipconfig". Look at the bottom line, it should read "Default Gateway". Write this down, and then open up your Internet Browser.
Type in the number sequence - it should take you to your router's configuration page, and from there you should be able to set up a WEP key for your network. It should be under "security" or a similar heading.
If you have further questions, come back and post!
Posted on Apr 09, 2008
USR MOdel 5461 Ce numéro
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
Jan 01, 2011 | U.S. Robotics USRobotics USR5461 Wireless...
I have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Apr 24, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
I cant menagment wit mu usrobotic i cant go insade him
www.usr.com/support/product-template.asp?prod=5461
get manual link above all explained with pictures.
Apr 08, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
I forgot my custom ip address of us robotics so now how i can connect to it
The default address for that make and model is: http://192.168.2.1
If you changed the default address, you can perform a factory restore to reset the router.
To restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
Mar 20, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
How do i find my network key or create one for security?
Login to your router and check to see if wireless security is setup:
Use Internet Explorer and type 192.168.2.1 in the address bar.
Login using the password you created when you setup the router.
You can view the wireless security settings and retrieve the key.
If security is not setup you can enable it....directions here:
http://www.usr.com/support/5461/5461-ug/wireless.html
Mar 11, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
Mac address
Look here:
http://www.usr.com/support/doc-popup-template.asp?url=5461a/5461a-files/clonemac/clone-mac.htm&loc=unst
If not, here is the support page:
http://www.usr.com/support/product-template.asp?prod=5461
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 25, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Password problem
Look for the quick setup in the box, or try this http://www.usr.com/support/5461/5461-ui/setup_cable.htm
admin admin is what you're looking for.
Carl
Aug 26, 2008 | U.S. Robotics Computers & Internet
Laptop wifi cannot find usr model 5461
I use the windows wireless zero program which all I read is the best for wireless and aliminates conflicks
Dec 30, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
Two routers US robotics connected together
It appears you may have confused the world because of your IP addressing choices. Do you know what a subnet mask is? It determines which machines share the same network with other machines. Routers by design are the connection between different subnets, Most routers default to 255.255.255.0 for the subnet mask which means both of your routers are in the same subnet as they are 192.168.2.? meaning you have two separate networks sharing the same same subnet address when they should be unique. Try making the wireless router 192.168.3.3 or 192.168.3.1. This puts devices in your wireless network on the 192.168.3 subnet and the devices in the ADSL subnet in the 192.168.2 subnet which includes the WAN half of the wireless router. I believe this will correct your network issues. In this case if hardcoded the gateway for the wireless router would be 192.168.2.1 also known as the the adsl modem
Dec 02, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
