Question about Sony KV-27S65 27" TV
Sony KV-27S65 27" Television suddenly has very low volume
My Sony KV-27S65 27" Television suddenly has very low volume even when set at full (all bars full). Also, the picture has wavy verticle lines. Could it just use a blowing out (dusty or dirty connections)? Your advice would be greatly appreciated. Thanks...
  • Todd Lunde Jun 04, 2010
    Thanks for your solution to my Sony KV-27S65 television problem. I have read about this common problem. I am a little confused about the tuner/IF module locations. My set definitely has two separate modules. I'm guessing the IF module is the one buried further inside the enclosure. The adjustment holes do not seem to be labeled on either, as far as I can see anyway. Also wondering if these modules pull out, or if they are soldered in. I have also read to ONLY adjust the "descr" screw, but am not sure. Also wondering if there is a simple diagram available of these modules. It's a little tough trying to make adjustments when you don't have a clue of what's what. Thanks again for your reply!...
  • Todd Lunde Jun 05, 2010
    This set has dual tuners, which have 10 holes with adjustment holes each. They are unmarked, and I don't want to just start turning screws without knowing what I'm doing, of course. Would you know of a diagram which just simply shows the schemtaics of the tuner layouts and adjustment labels? I'd like to try some adjustments if it is possible on this set. Also, there is no change in the very low maximum volume level and wavy verticle lines when inputing my Sony RDR-HX900 DVD recorder through video 1 (RCA cable). The picture is perfectly clear, however, when inputing video 2 through S-video from the DVD. The maximum volume level remains very low regadless. Any further help on this (common) problem would be greatly appreciated. I could send pictures of the board, etc. if i might help. Thanks...
    President:
  • 1,961 Answers
That problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Posted on Jun 04, 2010
I got a problem my tv sony trinitron kv-xg29m20 the problem is when the tv comes on the picture is not full the sound comes then suddenly its cutsoff and the redlight flashes
By not full I assume you mean the picture is reduced in size all round. If this is the case then you most likely have a power supply problem. Check the HT voltage, if this is low then check all electrolytic capacitors in the power supply for reduction in value.
Regards Vintie
Oct 15, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-32L535U Picture size
With your Remote Control MENU and enter in the search the option of screen and To get the appropiate that like for you.
Jun 18, 2012 | Sony Televison & Video
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Low volume on Sony Trinitron
There seems to be a failure in your output drive circuit.
All electronics fail suddenly and don't show any signs until the defect is noticed except in the cases of intermittent troubles From what you have described an intermittent defect is not the culprit here. Are you using external speakers or the internal ones in the set? If you are using external speakers disconnect them and see if the internal speakers work OK. If it's both channels at the same time it's in the electronics, not in the speakers. This would require internal service. Unfortunately there is no easy fix for that. Have it diagnosed (which they can't properly do in your home unless it's a very obvious problem) get an estimate first. Those sets are very well made and reliable but nothing is perfect. You need a service call or move it to a shop.
Mar 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron (analog) picture suddenly ''pulsating''
the verticle has a problem check the following around that area
capacitors
zener diodes
resistors changing values
what is happening is that a voltage is not constant, its varing
Mar 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Volume gone mad
Is there a ceiling fan in the same room? Under the right conditions, light reflecting off the whirling blades hits the TVs sensor at just the right frequency, causing mysterious things like this. Try covering the infrared sensor on the TV (it should be behind a red transparent piece of plastic somewhere in the front. If this keeps it from "going mad", then something in the room is to blame. If it still does it even when the sensor is covered, then it is the TV. Good luck, and let us know what you find!
Mar 23, 2007 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Sony KV-27S65 27" TV Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
