Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Will not start
New battery, no noise when trying to start
  • 36 Answers
Clean and tighten all connections from the positive cable all the way to the starter and selenoid connections too and try jumping the selenoid across and see if that kicks the starter over if it does that means the selenoid is bad
Posted on Jun 03, 2010
Cannot start loud fast clicking noise
Clicking noise would indicate starter solenoid faulty! This would also be the case if battery low but since you have a new battery you can look at the starter solenoid!
Aug 22, 2015 | Cars & Trucks
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
My 2005 nissan xterra won't start i bought a new battery still wouldn't start. but all lights and gaurges started to work. As were they didnt before the new battery
When you try to start does the motor spin but wont start or is there no noise at all, if its no noise at all then i would start by checking the starter and if it spins but wont start then try holding gas pedal down and cranking the motor with a dead battery it may have lost memory and will need to run awhile to relearn idle at start up and other readings you may need to hold gas pedal to keep running for a few minutes,start with this first.
Aug 03, 2010 | 2007 Nissan Xterra Off Road
Car will not start. A clicking noise when trying
It's either a dead battery or loose/rusty battery terminals, try to pour hot water on battery terminals and then tighten them if loose, if still it doesn't start and keep clicking and if you had the battery for more than 4 years then install a new battery (you can get a good one for around $50, don't buy expensive ones they do the same job). Hope it helps and please don't forget to rate the answer it helps me with my general ratings, thanks!
Apr 11, 2010 | 2000 Mercury Grand Marquis
My 2007 Nissan Xterra won't start. When I try to
SEE IF SOME ONE CAN GIVE YOU A HOT SHOT YOUR BATTERY MAY BE WEAK AND THAT CLICKING NOISE IS THE SIGN OF NOT ENOUGH JUICE GETTING TO THE STARTER
Oct 12, 2009 | 2006 Nissan Xterra
Will not start, new battery 3 months ago. think
it could be starter or altinator
try another battery if it starts with that its your altinator
if it was your starter it would make a clicking or whiring noise when you try to start it.
Oct 09, 2009 | 2005 Jeep Grand Cherokee
1996 Dodge Ram 3500 starting problem
It was a bad connection, replaced the clamps.
Jun 03, 2009 | 1999 Dodge Ram 2500 4WD
New battery ,makes a clicking noise when trying too start it
Starter solenoid bad or a loose cable to the starter perhaps
May 24, 2009 | 1998 Pontiac Grand Am
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
119 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
