Question about Campbell Hausfeld 13 HP 30Gallon Air Compressor CE7003
Compressor problems when filling tank
I have a campbell hausfield 13 gallon 4 horsepower compressor and when I PLUG INTO ELECTRIC TO FILL TANK THE COMPRESSOR BOGS DOWN AND BLOWS THE CIRCUIT BREAKER> Please help?
  • 59 Answers
There should be a device called an "unloader " connected to the machines own switch. This releases the pressure from the compressor so it can start up without the resistance of the pressure in the tank.There should be a hissing noise when the machine stops, the sound of the air on the compressor side of a non return valve being released.
Posted on Jun 05, 2010
How many liters of compredssor oil to fill tha compressor tank
I don't know which model of air compressor you own, some models require no oil whatsoever. The important thing to remember is that you should never put oil inside the tank. While it probably won't damage the compressor and may, in fact, be good for air tools, oil does not belong in the tank. The tank itself should contain clean, dry, air ONLY. Depending on the job you're performing, oil and water in the air tank will ruin your hard work, especially if you are spray painting. The air compressor motor does require oil (unless, again, it's oilless), just fill it through the oil filler hole until it barely starts to leak out. You can change the oil every year if you use your air compressor professionally. Most people who use their compressor only occasionally never change their oil or even check the level. My compressor is a 20 year old Campbell Hausfield with the original oil. I don't recommend that, just stating the facts...I do religiously drain the water out of the tank with the drain valve, and I have replaced the drive belt. Once.
Feb 25, 2015 | Air Tools & Compressors
My compressor will not fill up. It starts and sputters a little then kicks off. It is the garage and a little cold. Like 40 degrees.
relieve all the pressure from the tank and then try it. also make sure your not on a long extension cord. plug in direct if you can. may have a weak start capicitor.
Dec 26, 2010 | Campbell Hausfeld 26 - Gallon Air...
I have a 26 gal 5 hp upright campbell hausfield air compress. it will not buildi up air all of a sudden. it is building some as when i pull the pressure relief some air comes out. Any suggestions.
Hi, my name is John. Welcome to FixYa. check all your air lines for leaks, check the valve at the bottom of tank, check the line coming form the pump to the tank. You may have to remove it to inspect it. I find this one always is over looked. Thanks for choosing FixYa...John
Nov 15, 2010 | Campbell Hausfeld 2 Gallon Air Compressor
What type of oil is needed in my Durabuilt air compressor-6 gallon tank? I need to replace some oil. Thanx. Send response to "gfrommell@wi.rr.com." Thanx.
Howdy. It's actually called Compressor Oil and is available at nearly all hardware stores and tool rental agencies. There are several brands and they are all comparable. I use Senco, but Campbell Hausfield is also good. Farmerbear at FixYa.com
Oct 23, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
After starting the compressor, the tank does not fill up to 120 psi and shut the compressor off automatically. It will continue to run and not fill the tank completelhy. How can I fix this?
It could be one of three things. 1. The air intake could be dirty to the point that it cannot take in enough air volume with each cylinder stroke to be able compress it to 120. Try cleaning the air filter. 2. The reed valve that prevents the return of air from the tank to the compressor is not sealing well. This might be cleanable, but requires disassembly. 3. The cylinder itself has a poor seal giving you bad compression. This would require major surgery and parts, and is probably not worth fixing.
Jun 29, 2010 | Campbell Hausfeld FP2080 4 Gallon Portable...
Wanting to adjust my cut off pressure down...its at 135 now but have in line tank, campbell switch 60 gallon
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
Dec 02, 2009 | Campbell Hausfeld Air Tools & Compressors
Fuid inside compressor..do I undo drain plug !
Open the plug at the bottom of the tank while the compressor is on so that it will blow out all the crud. The black liquid is the gunk from the oil in the compressor and staknant water. When the crud stops coming out and you herar just air, you should close the valve and you are set to go. You should drain this tank al least once a month if you use the compressor a lot. I hope this helps. Don't forget to rate my answer. Thanks.
Feb 11, 2009 | Campbell Hausfeld 13 - Gallon Air...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Campbell Hausfeld 13 HP 30Gallon Air Compressor CE7003 Logo
235 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
