Question about Weedeater Excalibur Gas Hedge 22" Trimmer Blade
Hedge trimmer put away for winter. will run but not stay running. put in new diaframs for carb . same results. i am questioning the gas cap now. is it possible that it can cause a problem with keeping this trimmer running Paul
  • 416 Answers
YES, this system relys on pressure and the ionic nature of gasonline to pull the fuel through the system. If the gas cap is off or damaged where a seal is no longer possible, try taping it up with duct tape and see if that helps
Posted on Jun 03, 2010
  • Remote Computer Rescue
    taping up the bare hole that is
    or just hold your hand of the hole and see what happens.....
    its all about trial and error, taking what you know to be true and going from there
    We know that the system does rely on pressure created from the burning fuel to pull in more, and that you have tried the carberator, the only other thing i could think of would be a bad choke stuck open
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
My trimmer will start for a few seconds running only from the primer blub but will not continue to run from the main gas line. I can see that it is not drawing gas from the main gas line.
take the carb off then pull it apart and thoroughly clean every hole and part with carb cleaner, make shure you you clean the neddle valve and there is no biuld up on the floats. also mak sure there isn't any holes in the floats an in the diafram
Apr 21, 2013 | Garden
Will cut off after five min of running .does it need a new coil
Check gas cap first for vent being plugged as this will create a vacuum in the tank and prevent fuel delivery. Test when problem occurs by immediately loosening cap and retightening to see if restarts right away you might even hear air going into the fuel tank.
If it doesn't restart, possible coil. Coils are usually affected by the increase of heat when running having too high resistance in the electrical windings or possible moisture.
Nov 07, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
My hedge trimmer will not start... Put in new gas
It's not getting gas, due to being gummed up with old gas. Remove all of the old gas and mix up a batch of fresh gas&oil. Also get some carb cleaner. Put just a little of the gas&oil mix plus an equal part carb cleaner. Try to start it just to work the new mixture through the carb. You might use the spray start to help pull the new gas through. If it fires up on the new gas&oil&carbcleaner mix, shut it off and let it sit for an hour or two. Drain it out and try just a little gas&oiil without the carb cleaner. If all is well fill the tank. If not, repeat the whole process. If you can't clear the gum this way you may have to remove the carb to clean it. Good luck.
Oct 22, 2010 | Craftsman 22" Gas Hedge Trimmer
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
I have a gas powered trimmer .Model ut21566/serial no. atki713420. Dated 6-20-07. 26cc. 7hcps0264aj.Used brand new 6 times. Will not stay running . I checked fuel mix ok. I purchased at home depot.If you...
Clean your carb and give it fresh fuel. Thats if you are getting spark. Can you give me a note so I can give it to my teacher so I can get back into school.
Aug 20, 2010 | Homelite Factory Reconditioned 26cc...
Gas won't pump through the hedge trimmer
carb may need to be rebult. sounds like a bad diafram hope this helps
Jul 11, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Cuts out after 10 minutes
Sounds like fuel tank vent problem , air has to get into tank
sometimes its vented by fuel cap but a lot of hedge trimmers use
a duck bill valve right thru tank or hooked to hose .
To test if this might be the problem loosen gas cap when it starts to die .
good luck
Jan 20, 2009 | Garden
Weedeater Excalibur Gas Hedge 22" Trimmer Blade Logo
791 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Darrell
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
