Question about Cycling
How to change the lock code
The cyclotech lock for bicycles
Forget security code
It Locked to security code or password lock? You can get the master reset code and reset the phone from security lock...It locked to network means use the network unlock code to Unlock the Sim Network lock,Specify the Model and brand?You can get the Network Unlock code and Master reset code at hereUnlocking4free.com and Unlock it or reset it...You can try default code as 0000 or 1234 for Nokia to unlock from security lock ,if not works get the master reset code and reset it.
Sep 04, 2011 | Cycling
Just bought magnum 3016 coil cable lock. How do I open it and set own combination?
Thanks that worked for me to. To change the code open.....enter current code.......turn the metal wheel (saying set ->) clockwise until it stops.........set the new code........... turn the metal wheel anti clockwise until it stops.......the new code is set.
Apr 14, 2011 | Magnum Cycling
Have purchased a Kryptonite RCL 111 and upon wanting to use it the 0005 combination does not open the lock and hence I am unable to use the product. Can you assist? Thanks You Roland
brand new locks come preset with a ' 0000 ' code and then you can change it to whatever you want -- so I would try and set the wheels to all zeros ( 0000 ) and see if it will open then. if you bought this lock new and set it to a combo and the lock does not know the code then there is a chance that one of the combo wheels has broken ( this happens all the time ) --- take the lock back to the store that you bought it from and tell them that it is broken and they will replace it with a new one.
if you did set the combo but you forgot what the combo was or it was set wrong - then you can try and progress the combo by starting with 0000 ' try the lock ' then 0001,then 0002,0003,0004 etc.. all the way thru all the numbers until the lock opens,,, this does take some time and at the lock shop that I work at, we see this all the time and we try 'em in our spare time --- going from 0000 to 9999 usually takes about 1 1/2 hours to 2 hours to spin thru all the digits. ( this is really the only way to figure out the combo ).
c...
Jan 23, 2011 | Kryptonite Rcl 3 Combination Cable Bicycle...
I can't open my bike lock. I locked it without a problem, but can't unlock it. I can't find my manual, and is there a way to change the combination?
try pulling on the bar and turning the tumblers slowly one at a time if you feel the bar jump forwards turn the next tumbler this may unlock it and if it do you will have found out what the combenation is too, you cannot change the combenation unless the lock is open first! help full "A" it stops people nicking your bike?
Oct 24, 2009 | Master Lock Bicycle Lock
I forgot my code
I have the same issue. I just bought a bike and dug out my old bike lock from college. Obviously the codes I'd being using now are not what I programmed my bike lock originally with. Any suggestions??
I've been trying to listen to the lock when I rotate the numbers and crack the code. Not a fun task.
Sep 29, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
How do i reset the code on my jeep bike lock
you may need to do trial and error method to find jeep code.
say
111
113
113
114
121
123
124
125
126
127
211
212
213
214
. etc.
you will find code.
Sep 11, 2009 | Cycling
How to change combination
Hello Beryl. You can call a local locksmith or work with master lock at this link http://www.masterlock.com/faq/lostcombo.shtml
Joe
Jul 13, 2009 | Master Lock Bicycle Lock
Lost my extra key for my master lock bicycle horseshoe shaped lock. can i get another key?
yes. take your key to any lock smith shop and they will make u another one. J
Jun 23, 2009 | Master Lock Bicycle Lock
Bicycle Lock Problem
In order to break it you need a powerful tool you need to get something called a 'metal cutoff blade'. It will go straight through the lock, no problem. You can use it in a hand-held saw or a table saw.
To find a master key or open the lock you can also call a locksmith.
Good luck
Oct 29, 2008 | Master Lock Bicycle Lock
Cycling Logo
109 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
