Question about RCA DVR40 DIRECTV DVR with TiVo
RCA DVR40 Problem 1: My unit keeps pausing for a second or two at no regular intervals. When watching a football game, over the length of the game, it becomes about 10 to 15 mins behind regular programing. Problem 2: Very slow in reacting to comands, especially in the "Now Showing" Mode. Problem 3: Periodically shuts down and reboots. My email address is larryg@azwildblue Thanks
My RCA dvr 40 did the same.I think it was overheating.I vacumed the fan opening and put small blocks of wood under the legs and that worked for about 3 mos. then it said powering up but wouldnt. i'm now replaceing the unit. Good luck
Posted on Jul 04, 2008
Which site do you prefer to watch the Football highlights?
I love to play as well as watch football games. There are many sites that show football highlights. Pick a robust one. The site I prefer the most is 7m as it is a trustworthy place to get the football game highlights. With this, you will always keep updated with the live status of all the football matches!
Apr 12, 2018 | The Computers & Internet
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
Need to get a programmer dont know where its at
  • Windshield Wipers Continue to Run When Turn Signal and Windshield Wiper Switch Are Turned OFF
  • Damaged turn signal and windshield wiper switch .
  • Damaged windshield wiper motor .
  • Damaged windshield wiper control module.
Pin Number Circuit Circuit Function 1 57 (BK) Wiper Motor Ground (Park) 2 28 (BK/PK) Wiper Module to Wiper Motor (Park Switch) 3 65 (DG) Wiper Motor Power (Park Feed) 4 61 (Y/R) Wiper Motor Common (RUN) 5 56 (DB/O) Wiper Motor LO 6 58 (W) Wiper Motor HI
Windshield Wiper System The windshield wiper system consists of :
  • Windshield wiper motor (17508) (F-type).
  • Washer system.
  • Windshield wiper control module.
  • Turn signal and windshield wiper switch (13K359).
The windshield wiper control module is:
  • Located at the instrument panel fuse panel.
The windshield wiper motor is:
  • Attached to the cowl top extension (021A36) .
  • Connected to windshield wiper mounting arm and pivot shaft (17566) .
The turn signal and windshield wiper switch features a:
  • Rotary wiper switch.
  • Push type washer actuator.
OFF/Low/High Speed
  • Has a two-speed, permanent magnet, three brush electric windshield wiper motor .
  • The windshield wiper motor has a brush rigging that permits selection of low or high speed.
  • When the turn signal and windshield wiper switch is in the LO position, the common brush and the blue/orange wire brush are used, and the windshield wiper motor operates at low speed.
  • When the turn signal and windshield wiper switch is in the HI position, the common brush and the white wire brush are used.
  • In HI position, electric current will bypass a portion of the armature winding causing the windshield wiper motor to operate faster.
  • When the turn signal and windshield wiper switch is moved to the OFF position, the windshield wiper motor will continue at low speed until the park switch outer contacts open.
  • When the park switch contacts open, the windshield wiper motor stops in the park position.
Interval
When the turn signal and windshield wiper switch is in the interval position:
  • The wipers make single wipes separated by pauses.
  • The rotary switch is on the end of turn signal and windshield wiper switch .
  • The length of the pause can be set from approximately 1 to 17 seconds.
  • Length of pause decreases as the rotary switch is rotated away from off.
  • Length of pause increases as the rotary switch is rotated toward off.
While in the interval wiper mode:
  • It is normal to hear a slight click at the beginning of each on/pause cycle. NOTE: When using interval wipers, the first wipe may not occur until after a pause of up to 17 seconds.
May 27, 2009 | 1994 Ford Mustang
Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
Jan 09, 2007 | Swiss Army Wenger Standard Issue 70609...
Second Hand
it is the battery life indicater get the battery replaced it will fix the problem
Oct 26, 2006 | Swiss Army Wenger Avalanche 70186 Wrist...
Televison & Video Logo
263 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
