Question about Tefal Avante Deluxe 4 Slice Toaster
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Posted on Aug 19, 2010
Toast wont stay down
Don't eat the right side. It must be bad.
Nov 01, 2014 | Applica T4030-b & D T4030 4-slice Toaster...
Manual download
Here is the tefal home page for the classic 4 slice toaster. I believe it is the same taoster as you have described but let me kow if it isn't.
At the bottom of the page is a downloadable pdf manual for this toaster.
http://www.tefal.co.uk/Breakfast/Toasters/Tefal-Avanti-Classic-4-Slice/p/1500532718
Hope this helps
Jan 29, 2014 | Tefal 5332002 4Slice Toaster
How to operate it
web search -tefal avanti toaster operating instructions- 7th site down to download instructions
Oct 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
Can you email the user manual for tefal toaster avanti deluxe for me to download please
Hello Val,
Here's the link directly to Tefal's site where you can select the exact toaster manual from the list provided. I wasn't sure of the exact model, since Tefal has two (2) Avante Deluxe model toasters available (both a 2 and 4 slice version) and sometimes the Fixya site only has a limited selection for certain products for users to request assistance with.
In any case, they are all on the page at the link below. Simply click and you'll get a free manual that you can save or print out for your use and future reference.
http://www.t-falusa.com/tefal/Consumer_service/Use_instructions/HomeUseInstructionsTemplateFile.aspx?NRMODE=Published&NRNODEGUID=%7bC41F9AC8-8DCD-439E-8171-0CA2B8E9C7E3%7d&NRORIGINALURL=%2fConsumer%2bservice%2fUse%2binstructions%2fuse-instructions_home%2ehtm&NRCACHEHINT=NoModifyGuest
If it doesn't come up, simply select "toasters" from the pull down window on the screen and hit "go"
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to search the web for them.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Tefal Avante Deluxe 4 Slice Toaster
Tefal toaster wont stay down - Avanti Elite, twin.
Hi, I assume that you had the toast carriage pushed down when you check the solenoid (hold down coil) volts ? .. a bit dangerous to try though
Either way, try resoldering the solenoid connections, they can develop hairline cracks that limit the current.
Feb 11, 2008 | Kitchen Appliances - Others
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Tefal Avante Deluxe 4 Slice Toaster Logo
1,229 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
