Question about Whirlpool GR2SHKXKQ / GR2SHKXKT / GR2SHKXKB Top Freezer Refrigerator
Water LEAK...HELP!!! I have a Whirlpool 2314273-REL Refrigerator. Recently it started leaking water from the freezer to the underneath of crispers. I'm not sure what I should be taking off and looking at. All the diagrams online are different from my model. Please help.
I have had to clear the drain tube on my fridge several times, I have not figured out how to prevent it from reoccuring. UNplug the fridge first!!!!!
To unclog the tube you need to take the freezer lfoor panel off ( mine has 2 bolts holding it). Thaw any ice you see under the freezer floor panel and in the very back of the freezer. As the ice starts to disappear you will find a tiny opening about the size of a dime way in the back, this leads to the drain tube that goes all the way to the drain tray under your fridge. Get the heat in there (hairdryer) and then pour hot water in until you hear water flowing. A basting syringe works well for this part. Once you hear the water moving check the drain tray under the fridge, you may even see a corn kernel or a pea. If it is totally cleared you'll see water. Voila, put it back together and you're good to go.
Unless you get all the ise out you will find it hard to see the small drain hole..
If anyone knows how to keep this from reoccuring let me know.
Posted on Jun 09, 2010
  • Whirlpool Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Model # ET22DK, water is collecting underneath the crisper drawers.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Whirlpool Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool GR2SHKXKQ / GR2SHKXKT / GR2SHKXKB Top Freezer Refrigerator Logo
352 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
