Question about Maytag Neptune MDG5500AW Gas Dryer
Coin noise from drum - Maytag Neptune MDG5500AW Gas Dryer
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryercoin noise from drum - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jun 08, 2010
Noise from machine
1.check if the bra wire is poking out of one of the drums.Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2.clear the water pump from obstractions like coins or small objects there might be some coins stuck in it that are causing discomfort.
if all the above fails try to run the motor alone without the belt if you still hear the noise its the motor that has a problem
Oct 27, 2012 | Hotpoint Aquarius WD640 Front Load...
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Mod 110.67741600 ser mu2020976 dryer drum is makeing a lot of noise
Check the baffles in the dryer drum to see if any are loose. If they are not loose, spin the dryer by hand to see if noise is from inside the drum. Sometimes you will get coins caught in the baffles and all you have to do is loosen the screws, and rotate the drum a little so the coins will fall out. Then tighten the screws up and replace the cabinet. You may also have a bad drum roller inside the machine.
If you could describe the sound to me, I will be able to help you a little more.
Jan 06, 2011 | Kenmore 700 6973 Dryer
Noise in drum sound like its gonna blow up
hello, unfortunately the wf321 drum does not split the bearings and drum come as one complete unit and so you need to order a drum unit complete with new bearings and replace the lot
Jun 02, 2010 | Hotpoint Washing Machines
UBNORMAL SOUND DURING DRY SPIN
Washing machine is noisyIt's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently.
Here's a general guide though -
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  • Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
  • Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  • A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  • A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  • A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
  • Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk. If you have a specific noise you are concerned about, either call an engineer
Apr 11, 2010 | Samsung Washing Machines
It makes a loud noise whilst drum goes round
This is indeed a known issue in LG dryers. Mine does the same thing. Instead of contacting LG, I contacted an LG authorized serviceman. He advised me that replacing the rollers would still make the same noise. The LG techs that he spoke with (these are REAL techs, not the bozos that the consumer talks to) said that the problem can be minimized by selecting the Wrinkle Care option. After the drying cycle is over, Wrinkle Care will tumble the clothes 5 revolutions or so, every 10 minutes. This keeps the rollers round as they are cooling down. It does help, as mine still thumps on start-up, but not for nearly as long. I have come to accept this as a small price to pay for a superb dryer.
Apr 06, 2010 | LG WM-2277HW Front Load Washer
Noisy bearing
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
    there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
    Mar 02, 2009 | Kenmore 63942 Dryer
    Makes a noise like there are rocks or coins when it spins
    If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
    Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
    Maytag Neptune MDG5500AW Gas Dryer Logo
    104 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
