Question about HP PSC 1410 All-In-One InkJet Printer
I misplaced my connecting cable ie printer to laptop
Foolish question i am sure what type of cable to i need to connect my lap top to my HP1410 i have one but it doesn't connect properly?
Thank you
    An expert who has answered 500 questions.
  • 564 Answers
USB interface cable..Radio Shack or Frye's keeps these in stock..usually around 5 to 7 bucks
Posted on Aug 19, 2008
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Hi i have the canon mp490 all in one printer and i was just wondering how to i get things to print from my lap top
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
Aug 05, 2011 | Computers & Internet
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
Inability ro scan to new laptop
Before scanning from the printer front panel, make sure your Solution Center is properly installed. Try scanning from the Solution Center first. The status of the printer should say ready before scanning.
Mar 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Connection problem
The first thing to check is that both of your computers are assigned to the same workgroup name. Right click 'my computer' and select properties. Change the workgroup name so that they are identical on both machines. You will need to reboot if you change the name one one or both of the machines.
Jan 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a hp deskjet f2180 all in one printer scanner copier we have tried to add to my lap top but the lap top does not recognise the hp deskjet f2180 and we dont know what else is compatable with
What operating system are you running on your laptop? This model only supports Windows 2000/XP/Vista and Mac OS/X. Make sure you have installed the printer USB drivers (included on the printer software CD) first. If you are connecting the printer directly to the laptop, all you should then need to do is connect the printer to the mains power, turn it on, and connect the USB cable between the printer and the laptop. If you are connecting to a printer that is connected to another computer, you mus make sure printer sharing is enabled on the computer the printer is physically connected to.
I may be able to provide a better solution if you can provide more information on your Laptop operating system and how the printer will be connected.
Jun 15, 2008 | HP Office Equipment & Supplies
If you move your laptop screen to were it works sometimes and doest work other, it sounds like it could have a loose connection in the ribbon cable. Most laptop lcd screens are connected to the main board through a brown looking ribbon cable. if this cable has become loosened, then yes it can be a DIY type job.
if you attempt to take the laptop apart, i sugguest you keep a record of what type screws go where.
Brad Nelson
Feb 20, 2008 | Computers & Internet
HP PSC 1410 All-In-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
