Question about Dryers
Dryer will no longer run or heat
Dryer will run only when Push to Start switch is pressed and held down - dryer stops as soon as pressure on switch button is removed
Dryer won't heat - it dried a load of towels last night but is kaput today Circuit Breakers are OK (resetting breakers did no good)
  • randallwilde Jun 03, 2010
    To: FixAllPhil
    Model No. 68932790
    Serial No. MG48044095
    I will remove motor and look for replacement or repair
    Many Thanks, Randy
    President:
  • 949 Answers
The symptoms you are having are consistent with a bad centrifugal switch in the motor.
When the motor reaches full speed (about 1/2 second after pushing the button) a switch inside the motor is tripped to hold the motor on and send power to the heat circuit. If this switch is bad the motor will not stay on with the button up and the heat will not come on. To fix this the motor has to be replaced.
A typical motor repair on a dryer runs about $275.00, If you can send me the model number from the tag just inside the door I can give you a better idea of cost.
Posted on Jun 03, 2010
  • Philip Jun 03, 2010
    Hi Randy,
    The motor is part number 3395654.
    Phil
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Dryer stopped heating, still tumbles, also the push to start switch has to be held down now for it to work at all. checked voltage (good) checked cotinuity of all parts and all were good except the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 09, 2011 | Kenmore 63942 Dryer
Kenmore Elite electric dryer model # 110.64994300\r\n I'm pretty sure I need to replace the push to start switch because it starts when I push it but stops when I take my finger off of it. So I held it...
I don't believe replacing the switch is going to fix the problem. provided the power cord is wired correctly you have a control board issue. Their is a small micro computer in the the console that will cause your exact concern start while holding the button the stops, and no heat.
Sep 22, 2010 | Kenmore Dryers
Whirlpool Super Capacity Dryer Front Loader 7kg : Drum does not want to tumble after push-button start. I opened the door and held the door switch in position as if door was closed. Then turn the drum into...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 24, 2010 | Whirlpool Dryers
Dryer won't run when push button it will run for awhile then stop. push button again it will not run humming sound replace starter switch did not help
you have a bad motor,that's what is humming,it's heating up and cutting out,when it cools down it will start again but soon that will stop also
Jan 23, 2010 | Kenmore Dryers
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
May 05, 2009 | Kenmore 73952 Gas Dryer
Dryer will not turn on and stay on.
Hello , bad news here , when you press the start button it sends power to the motor and then a clutch sets in and closes a set of points that then sends power to your element -if the clutch does not engage the motor will not continue to run or send power to the element and that is what is happening to your dryer.
not an easy fix at all , the clutch is bad and its located inside the motor and the entire motor would need replaced to repair this problem. they range from 80-100 dollars and would take about 1-2 hours to change.
let me know if you have any other questions.
Phil
Jan 12, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
