Question about Maytag MDG3500BWQ Dryer
The flame does not light no heat - Maytag MDG3500BWQ Dryer
    President:
  • 1,430 Answers
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Jun 03, 2010
Patio Heater starts but flame is low and it goes out quickly. Presumably this has nothing to do with the pilot light or starter flame because the heater main flame has been started.
This sound like the thermocouple or flame sensor is bad .
Thermocouple is connected from gas valve and it sits next to pilot so when flame is established this heats up and tells the unit to stay on ,same as a flame sensor
May 17, 2017 | Heating & Cooling
My furnace is a Rheem has issues of pilot light not staying lite the flame blows out won't stay on long enough to heat house
First thing I do, especially if the furnace is an older one, is to light a match or long end lighter(like for BBQ pits), hold it inside the opening on the front of the furnace heat exchanger, where you would normally see the burner flames, then turn on the fan only. If you see the "flame dance/flame disturbance", then that furnace may be unsafe due to a cracked heat exchanger. Holes or cracks in heat exchanger will blow out the pilot by allowing the air that we breathe to enter the heat exchanger and mix with the combustion process. AND may cause carbon monoxide poisoning. In that scenario, I would call in a professional. Now if it's not a heat exchanger issue, the flue pipe may have a back draft issue. Again, call a professional! Play it safe with that issue. Hope this helps!
Mar 14, 2017 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
My gas water heater pilot light will not stay lit
Hi Mike,
1stly you have to understand what the pilot light does!
Yes, it lights the flame, but it protects you from gassing yourself!
that is thye main job!
hava a look inside!
In front of the pilot flame, (it might have a double flame... (one flame on the bottom & another on top.) is a curved piece of metal plate. The flame is supposed to heat that plate untill it it very hot! Thenm the plate bends down as it is a bimetyaalivc strip!
This opens the bsaety valve & you can let go.
The flame will noe stay on. If a gush of wind blows the flame out, the strip will cool & the safety valve close, preventing a dead family in the morning.
There is a newer system as well.
Right in front of the flame, is a pointed sensor with it's tip in the flame. . It has a electric cable running to a safety valve. This sensor have to heat up as well. It is a heat battery that activates the valve. See that it did not move!
If it heats up, & the valve does not keep the pilot flame going after a few seconds, the unit has to be replaced!
Safety first!
Andy
Sep 04, 2011 | Water Heaters
On my patio heater the pilot light will light but goes out as soon as I release it, even after holding it down a long time. I can't get it to stay on to light the heater.
Check that the pilot light is directed at the thermocouple, a copper 'tube' that heats up when the pilot light is lit. You should be able to see a copper coloured small tube that the pilot light is directed at - if the pilot flame is not heating that tube then the main burner will not light.
If the thermocouple is being heated correctly, then it could be a fault with the thermocouple itself (can be replaced) or the gas valve.
If the pilot flame is not heating the end of the thermocouple you should be able to adjust its position so that the pilot flame is directed at it more accurately
Jan 18, 2011 | Rta International Patio Heater
The furnace will light up and the fan will blow but the flames cut out before my house reaches temp. i have the thermostat set at 70 and the house will not get above 55. i have tried turning the propane...
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, so by cleaning it you have almost restored it to its new condition. Seldom, but sometimes they do go out completely.
Dec 08, 2010 | Coleman Heating & Cooling
Will light and remain lit 5min. 30min i dont think its thermocouple thinking something with the safety tilt
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, by cleaning it you have almost restored it to its new condition.
Nov 08, 2010 | Heating & Cooling
My propane fireplace pilot light wont stay lighted help
Most gas valves have a flame sensor, which is a metal bulb at the end of a wire. The pilot light heats this bulb, and the valve stays open because there's a flame. If the flame has been out, you'll need to hold down the pilot light button for as much as two minutes after lighting the flame to allow the flame to heat the flame sensor up enough to keep supplying gas when you release the button.
Mar 17, 2010 | Desa International CCL3018N 18KBTU VNTFRE...
No heat
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
Jun 22, 2008 | Sharp R-353 Microwave Oven
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
