Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
I want to run a 3/8 pitch 0n my 028 do i need to
I want to run a 3/8 pitch 0n my 028 do i need to change the sprocket
    President:
  • 2,220 Answers
The following is copied from the Oregon FAQ "What is pitch".
Chain pitch is the distance between any three consecutive rivets divided by two. Pitch defines the size of the chain. OREGON® chain is made in several pitches - 1/4" is the smallest, 3/8" is the most popular. Other parts of the cutting elements are pitch-related. The drive sprocket must be the same pitch as the chain, and so must the nose sprocket in sprocket-nose bars.
An illustration and the original question is here: http://www.oregonchain.com/pro/service/faq.htm
If the result from an existing chain is 3/8"s or 0.375" then you need not replace the sprocket. If the result is different then the drive sprocket and bar nose if sprocketed must be changed. Chain gauge must also match to prevent problems.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jun 03, 2010
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
Why doe my sprocket on Husqvarna 455 keep tearing up the drive part of he chain
Are you sure the pitch of the chain is the same as the sprocket, ie if you are running a 3/8 pitch chain you need a 3/8 sprocket, if this is correct then you need to address your chain tention and sharpening.
Aug 18, 2013 | Husqvarna Chain Saw 20" Bar
I need to change the drive sprocket on a 028 av super i am having problem getting the old sprocket off whats the trick
is the chain brake still applied, thus gripping the drum on the sprocket.. Remove the E-clip and take the chain brake off... clutch drum should lift out.
Sep 15, 2012 | Stihl Garden
What bar and chain for a 359 chainsaw husky
Depends on what lenght you want, as standard it runs a .325 pitch, 058 gauge chain, bar lenghts are available in 13,15,18,20", you can convert them to a 3/8 pitch chain by changing the the rim, or changing the complete sprocket and oil pump drive gear.
Sep 10, 2011 | Husqvarna Garden
I have husquavarna chain saw s/n 95212H01984 with sticker that says 41 Air Injection. Need to buy chain and/or chain bar. Need to know the model number for this serial number. Can you provide
The saw is a 41, as standard it ran a 15" bar and chain, in the UK it ran a .325 pitch, however in the US, it ran a 3/8 pitch chain, as you should change the sprocket if fitting a new chain, i would put it on .325 if it is not already, the sprocket is part no. 530069342, the 15" chain is 501840664, and the guide bar is 508926164 these are .325 pitch 050 gauge and 64 drive links, this combination will cut much faster than the 3/8 low profile combination.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
After new clutch sprocket &good bar &chain chain r bar moves prematuely and chain comes off bar nuts r tight
have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
.325 x 0.50 gauge , .325 x 0.58 gauge
3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
you could even have the correct drum but wrong rim sprocket on it
worst case is you could have mismatch bar and chain
make sure that bar adjjuster assy is working correctly
recheck chain / sprocket pitches and bar pitch and groove
gauge
be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
is the clutch cover pulling down tight ?
have a look and let me know if and what you find
cheers paul
Aug 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need the specifications on a 1996 Kawasaki Ninja Zx6R Rear Wheel Chain. I need to buy a new one and don't know what size/specifications I need.
You need the pitch, roller width, roller thickness (All in all just the chain type) OEM is a 525, 108 link chain with a 15 tooth front sprocket and 40 tooth rear.
It is best to change sprockets and chain together. A stretched/worn chain will damage the sprockets which in turn will lead to premature wear on a new chain.
Best way to identify pitch(and chain type) is to measure the sprocket width(thickness).
  • 0.227" (5.76mm) - 520 chain
  • 0.284" (7.21mm) - 525 chain
  • 0.343" (8.71mm) - 530 chain
Technically speaking they all have the same pitch (5/8") as you can see they are of different widths. Please note that a 420 and 425 have the same widths as 520 and 525 but their pitch is different(0.5")
Further you will have to decide between stock, O-ring and X-ring. X-ring being the most expensive(and supposedly longest lasting) but in my experience lasts the same as an o-ring chain.
Aug 11, 2010 | 1996 kawasaki ZX-6R Ninja
NEED NEW CHAIN DRIVE UNIT INCLUDING PLASTIC
The model 028 Stihl Chainsaw was in production for many years and the clutch drum sprocket (or chain drive) came in three (3) versions over the years of production.
For several reasons, it is best to take the saw to an authorized Stihl Dealership (Locate your nearest dealership HERE) for production identification, evaluation of cost-effectivness and availability of parts.
Reason 1) The first-generation 028 saw is approaching 30 years old.
Reason 2) Extreme heat caused by a locked chain-brake can damage the engine case and render the saw unfixable (part support is going away due to age).
Reason 3) The shear cost of parts and amount of time it would take for a DIY repair.
Reason 4) The plastic gears you mentioned are the drive system that make the chain's oil pump work. If the plastic is melted, the oil pump is likely to be damaged as well. In most cases the oil pump cover gets damaged ... the list goes on and on.
Genuine Stihl parts are not sold online and aftermarket parts would be a gamble. It's up to you to decide if the cost, time and effort are worth it.
Hope this helps.
Oct 04, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Poulan Super25DA old chainsaw from the mid 70's.
Call your local Power Equipment Dealers and ask if any of them deal with OREGON replacement parts.
OREGON makes clutch drum, chain and bar combinations in the thousands!
NOTE: Along with clutch drum and chain replacement, your bar will need to be changed also, as the sprocket-tip in the nose of the bar will be a different pitch.
Oct 01, 2009 | Garden
HUSQVARNA MODEL 50 BAR AND CHAIN UPGRADE
I have a nearly worn out 42 cc Husquvarna that uses a 20 inch bar very successfully. With proper filing of the chain you should be able to run a 22 inch bar very well. Ensure that the roller nose on your new bar matches the pitch of the clutch sprocket that you are using at present. If not, have your chain saw shop change them so they match.
I would advise that you change the bar and sprocket to use a .375 chain as this will be easier to sharpen successfully than the .325 pitch chain you might be presently using.
I am six feet tall and short bars are murder on my back so this is why I use no shorter than 20 inch bars on my saws.
Jan 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
242 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
