Question about Olevia 237T 37 in. LCD TV
My tv keeps saying no channel listed. I did a
My tv keeps saying no channel listed. I did a channel search but that does not work. It was working fine but I don't know what happen
    Problem Solver:
  • 18 Answers
Do you have the digital converter. YOu need to swith the mode to video to view like charter or comcast
Posted on Jun 03, 2010
My lg 65UF6450 has no TV Guide. It searches for active Channels but finds none. Setting them manually doesn't work either. My satellite TV service is on HDMI2 and works fine, just no TV GUIDE.
I have a TV like yours.
When you hook up an external antennae to pick up over the air channels, the TV will find the channels and display a list.
Your other TV services should come with their own channel guides.
Mar 10, 2016 | LG Televison & Video
Olevia tv
This is not the fault with its remote control. Check and replace its tuner. Contact any service technician. Try these codes. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
TV is showing no signal. So I did a channel search and it stops and says unable to continue channel search due to error. I even unplugged - left for an hour and still does the same thing. I then hooked...
this could be a fault with the tv actual connector for the cable check the connection on the tv and try again or try a manual search to pick up one channel and then do a full scan also are you doing a scan to add channels to the current list as I would personally try and do a complete scan for all new channels list and see what happens
Sep 21, 2013 | Televison & Video
Sign keeps flashing " please do auto channel search "
TVs require a channel search when first started up/turned on so it can generate a channel list. check in the manual of your tv for instructions on how to do this.
Jun 17, 2010 | Insignia IS-LCDTV32 32 in. Television
Tv screen says no channel listed
Do you have a separate cable converter? In that case, the tv must be set to channel 2,3 or 4 (depending on the box) and you use the converter's remote to change channels. Otherwise, go into the setup menus for your tv and look for 'tuning' or 'source' and make sure it's set to 'cable' and not 'antenna'. Hope this helps!
Mar 04, 2009 | Olevia LT32HVE 32 in. LCD Television
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Olevia 237T 37 in. LCD TV Logo
180 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
