Question about Motorola Mobility W376 Cell Phone
When entering a name in the phone directory how do you get the second name to start with a capital. Example John D
  • 20 Answers
I think it is the same as a RAZR and you just press the up button on your cicrle on the key pad.
Posted on Jun 04, 2010
Cs6629 how do i enter numbers on to key pad instead of numbers
Assuming you want to enter a name into the directory, simply keep pressing the appropriate key until you get the desired letter. For example, if you want one of "ABC" then keep pressing the "2" key to cycle through these letters.
Dec 30, 2013 | Panasonic KX-TG2357 Cordless Phone
How do I edit a phone number in the system directory? Regards John
The system directory sits in system program 001. It's access from the control phone, usually the first one in the system (101) and from there you press PROG **1234 and dial 001 ENTER If you keep pressing ENTER it will step through the numbers from 001 to 999, or between the first and second ENTER you can dial a 3-digit number. EXIT a few times or pick up the handset and drop it back down exits programming.
Carl
Jun 17, 2011 | Panasonic KX-T7630 Corded Phone
How to transfer files from one partition to another using dos command?
hi if you wont move command
then try
go to the source dtive
[ example c: ]
then
move filename sorce_address source filename dest_address destnation_filename
example c:\>move text.txt d:
if you wont copy use copy insted of move
if you wont copy/move all files
then
c:\> copy *.* d:
if any problam replay me
May 02, 2011 | Microsoft Windows XP Professional
It asks to enter the correct name
Ascertain that the details type keyed are authentic. For example, type keys the users user names also passwords provided at account membership establishment. Second, ascertain that the computers type keypads have the appropriate settings. For example, in situations that the member's credentials have impression of capital type keys is mentionable mean to attaining login. Also, navigate through the computer page area to capture what is required to attain logon. Especially with member accounts that have compromised the initial attempts to login requesting alternative passwords or usernames as measure to protect unauthorized entry to personal spaces.
Mar 11, 2011 | Facebook Social Network
How do I input names on address screen in all CAPS
When you are at the "Enter Name" screen while adding a contact to your Phone Book, press the "*" key to switch between modes. You can check which mode you are in by looking at the box in the upper-righthand corner.
"Abc-W" mode will capitalize the first letter of each word
"Abc-S" mode will capitalize the first letter of each sentence
"ABC" mode will enter in all capital letters
"abc" mode will enter in all lower case letters
"123" mode will enter only numbers
You may switch between modes while entering the name if , for instance, you need to switch between letters and numbers,
Nov 02, 2010 | One Touch Jitterbug One-Touch Cellular...
Cannot find directory in commamd prompt
you want to open commamd prompt? press start+R and type cmd
Oct 26, 2010 | Computers & Internet
How do i change my phone from numbers to letters
I am not sure about the brand & model number you are using. But in NOKIA phone you need to PRESS # for more than 5 Seconds then it will change to letter, word & vice versa.
Thanks...!!
Oct 17, 2010 | Lands Phones
How do oyu activate voicmail on the T7316E?
Press "Feature 9 8 1" to open the mailbox.
The system will prompt you for the password - enter the default password "0 0 0 0". The system will prompt you to change the password - it must be between 4 and 8 digits, and cannot start with zero. You may have to enter your new password a second time.
Next the system will prompt you to record your name for the company directory (ie: "John Smith at extension 23"). You have the options to listen to your recording, retry, and accept it.
This will bring you to the mailbox main menu, where you will see how many new and saved messages you have. Finally, you can record a mailbox greeting. Press "ADMIN", "GREET", "RECORD", "PRIME". Here you can record your primary greeting. Press release or hang-up when you are done.
Hope this helps!
Nov 16, 2009 | NorStar T7316E Corded Phone
Revising extension directory on LCD
Correct. Changes are done in system programming. In a TDA it resides in system program 004. You get there by going to the main phone or phone used to program, dial PROG **1234 004 and enter the extension number of the name you want to change. It will display the present name and let you use the keypad to spell out new names. For example 2 gives you ABCabc2. The right arrow steps to the next character and ENTER saves it.
Carl
Sep 23, 2008 | Panasonic KX-T7633 Corded Phone
System Directory
I assume you have the manual. I found it very difficult to follow, very poor. While "on hook" enter the number you want to call. Press "store" or "enter". Enter the name referring to the graphics chart on pages 7 & 8. It is set up for Alpha characters and it depends on which software is installed on your phone. Example: If you want the letter "A" you press the number 2 one time. If you want the number "2", you have press "2" seven times to display the number 2. Use the toggle key to move to the next letter or number you want to enter. When you have finished press "Store". It may take awhile but that's how its done. Not a very good system for the average consumer in my opinion. But that's how its done. I was unable to upload the manual. Here's the link if you don't have it: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630
Sep 10, 2007 | Panasonic KX-T7630 Corded Phone
Motorola Mobility W376 Cell Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
