Question about Intermatic Inc. ST01C Digital In-Wall Timer
0141224 on installing i have comeing from the wall set of white wire then one black onits own and two other black joined together which di i attatch the red and black to
Open following link for clear description and illustration of Utilitec wiring.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Posted on Apr 26, 2011
I have installed the Utilitech timer switch # 0141224 with all of the wires connected as they are explained in the installation packet. The timer works and turns on the lights, however it only turns on 4...
Utilitec is single-pole timer.
Wiring sounds correct. Lights will blink if timer white white is connected with timer red wire. Lights will not turn ON if timer red and timer black are reversed. Green to ground is not necessary for timer operation.
Check light bulbs are operational.
Bundle of white wires are neutral wires.
Timer white wire requires neutral connection to complete circuit to timer electronics.
If bulbs are good, it is likely that loose white wire is problem, since each of the outdoor lights also needs neutral wire to complete circuit.
Having 6 white wires connected together, plus stranded wire from timer, takes a large wire nut, and that many wires can have a wire fall loose without notice. You can solder wires together, or break the group apart under different wire nuts with a jumper wire between.
Resources:
http://waterheatertimer.org/How-to-twist-electric-wire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Aug 15, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a 7-DAY DIGITAL-IN-WALL TIMER model number #141224. I have tried calling you peopel at least 6 times, staying on the phone for as long as a hour, and I still cant get you. I am having...
A) Open following link to identify timer and download instructions.
B) This timer is for single pole only and will not work for 3-way switching.
Timer does not have astronomical function.
C) If lights are blinking, timer is wired incorrectly.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
D) If you have trouble with programming, add a comment and say specifically where you are having problem for return comment.
I have programmed and tested this timer. Information above is accurate and tested.
E) Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 14, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a ground and white wires and a black wire... which do I hook to what... can I put green ground, and black with black, but can't i put my red and white on the white? For 7-Day Digital in-wall timer...
Utilitec 7-day timer will only replace single-pole switch.
Single pole switch has two brass screws and a ground screw.
Links below show wiring for both Utilitec 7-day timers
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
If this is not your timer, then add a comment and specifically state which timer you have and which wires came off which screw on old switch.
The best way to start is to identify exactly which wires came off old switch.
How to wire
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
If the free answer is not right for you, then take advantage of fixya phone service.
Expert helps you via phone for a price.
Dec 30, 2010 | Garden
I have a utilitech 7 day in wall digital timer and would like to install it but have no clue how to. can you get me started
You want to install Utilitec in-wall 7-day timer that has 4 wires: red, white, black and green.
You are replacing a single pole switch that controls a light or several lights.
There is not a second switch that controls same lights.
The switch has 3 wires.
Generally there are two insulated wires and a bare ground wire.
Add a comment any time.
Here's what to do:
I have tested these timers for wiring and programming.
Get started and instructions will make sense as you go.
Turn off circuit beaker to switch.
Remove old switch.
1) Timer-green-wire connects to bare ground wire using one of the yellow wire nuts included with timer. Put two wires together so they are even at ends. Put wire nut over wire ends. Rotate wire nut clockwise between fingers until very tight.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire using two more yellow wire nuts. Choose either one for now. You may have to reverse these two wires in a minute.
3) In back of electric box are white wires twisted together and covered with wire nut. Remove the wire nut, but do not untwist the white wires. Connect timer-white to these wires. Then put original wire nut back over white wires.
4) If electric box does not have white wires described in step 3, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires from step 2.
If you need help programming 7-day Utilitec timer. Pages have bigger print:
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
If your box contains 2 and only 2 wires, then the Utilitec timer will not work.
You need the Intermatic ST01C or EJ500 timers that operate with a battery.
I have tested the Intermatic and Utilitec timers:
http://waterheatertimer.org/ST01C-program.html#wire
Do not connect white and red wires together on any timer, but thank you for solving the problem why lights blink when connecting timers.
Now lets look at your wires.
Scrape paint off the wires so you can identify white and black.
According to your information, the black wire inside box will connect to timer-black wire.
The red wire always goes to Load (your light, fan, motor)
The white wire is necessary to complete a circuit so the clock inside timer will operate.
The timer has a clock just like your alarm clock, and it needs to connect back to neutral busbar in breaker box.
This is why the battery-operated timers will work with two wires, the clock runs on battery.
The Utilitec timer-white wire is the wire that goes to Neutral
The timer-white wire is supposed to connect to the other white wires that are twisted together and covered with a wire nut ... but some boxes do not have this neutral wire
To work-around, the timer-white wire can also connect to a bare ground wire.
The bare ground wire also connects to Neutral busbar in breaker box
If you do not have a neutral or ground wire as described above, then you need the battery-powered ST01C or EJ500 Intermatic timers.
See if you can pull some more of the wire into your box ... there might be a ground wire that was cut off and pulling more wire might reveal a ground wire. This will salvage the project.
Aplus is one of many places that sell the Intermatic timer
http://www.aplussupply.com/intermatic/timer.htm
For more about electric wiring:
Oct 23, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Tried to install a ceiling fan to replace a chandelier. light on fan and fan itself works but only by the pull chains, it will not turn off or on by the wall switch that controlled the light. when i...
I can help with this but I need some more clarification. Does the switch on the wall not do anything at all, or does it turn them both off or on. The black wires are the power wires and the whites are your neutrals. You figure out what wires are coming from your switch. If there was a switch on the wall that controlled your chandelier before that there has to be a white and black wire that go to that switch. Look at the switch in the wall. If all you see in the switch box is a black and white wire then they did a switch loop, which means they started the power up in the fan box, sent it out to the switch through the white wire and brought it back to the fan through the black wire in which case the one white wire up in the fan box is a powered wire. If there are four wires in the switch box (2 black two white), then they brought the power into the switch box, tied the whites together as neutrals and connected the blacks to the switch. So then up at your fan the white is neutral and black is power. To wire a switch loop at your fan, find the power wire, connect it to the white wire that goes out to your switch and the black wire from your switch will get connected to your fan motor and fan light. If it was not a a switch loop connect fan to the black coming from the switch and all whites will get tied together. Good luck!!
Apr 16, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Wall Oven - Connecting three wires to four
as long as the incoming power comes from the main power panel, then black to black/red to white these will be your 2 hot phases/the other white and 2 bare wires will be the neutral connection
Nov 14, 2009 | Audio Players & Recorders
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
186 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
