Question about Samsung BD-P1500 Blu-Ray Player
Since watching avatar on my samsung BD-P1600 i am now unable to watch any other bluray discs? The message keeps stating unable to play this disc. I have tried various other films but still nothing. Also downloaded uptodate firmware but still not working, help!!!!
    Scholar:
  • 121 Answers
If you're feeling ballsy, you can leave a disc in there and open it up (obviously, don't leave it plugged in while opening it up). Once you've located where the drive is, you can fire it up (with the disc inserted to block the laser from burning your eyes out!) and see if it spins.
If it does spin, it may be either a dirty or dead laser.
If the laser is firing AND the disc is spinning, then it may be a dirty lens. This is what I'd try before trying to peek at the laser (as that IS DANGEROUS). Take some rubbing alcohol and a Q-tip and, after unplugging the bluray player, remove the disc and apply a tiny amount of alcohol to the Q-tip. It should only be slightly moist, as excess alcohol can get into where it's not supposed to be. Gently rub the lens with the alcohol and then use the dry end of the Q-tip to pick up any excess.
If you're REALLY feeling ballsy, you can take a quick little peek from a distance and see if the laser is even firing. I wouldn't suggest it, as any reflection of the laser can suddenly send it straight into your eyes, leaving you blinded.
If it doesn't spin, then it's possibly the easiest and safest fix of all. Get some WD40 or silicone spray (any light lubricant designed for small mechanical partts and electronics, preferrably WD40) and spray some onto the shaft of the motor that spins the disc (it'll be right beneath where the disc rests as it spins). Quickly spray a tiny amount of WD40 onto the shaft and manually spin it a few times. Do this about 2-3 times and then put the disc back in and fire it up. If it doesn't start spinning, then try to spin it with your fingers. If it seems to be trying to spin on its own when you push it, then just go back and work a little more WD40 onto the shaft.
If none of this works, then one or more parts of the player are fried. You may be able to simply replace the whole drive if you want to keep the unit, though most people just replace the whole thing as it's less frustrating and sometimes even less expensive than fixing it.
Always remember, excercise caution while performing any repairs on any electronics. Even a 9V battery can be potentially fatal if given a low enough amount of resistance to pass through. Never work on anything that's on (or even plugged in for that matter) and don't just immediately dive into it after unplugging, as the capacitors need at least a count of 5 (as my rule of thumb) to discharge.
Posted on Jun 03, 2010
    Problem Solver:
  • 18 Answers
The player is defective. Try resetting it!
GOOD LUCK
CNBY
My samsung bd-p1600 will not play blu ray movies
If it plays other Blue Ray discs OK then either the disc is faulty or it is the wrong region. If it previously played, then my bet is that the disc has a scratch or dirt on it. If you have another blue-ray player or you have a friend with one try it on that or theirs.
Jul 31, 2016 | Samsung Televison & Video
My Samsung BD-P1600 will play a SD disc but the rental Bluray discs won't play. Is there any way to reset the player? THX.
It is not the player you need to reset, it is the rental DVD's. They are encrypted with a code to limit the amount of time they can be watched, thereby protecting them from being stolen or not returned. Send them back to the rental company and rent the same movies again. That is your only solution. Your player will play whatever is put into it. I hope this helps.
May 22, 2011 | Samsung BD-P1600 Blu-ray Disc Player
New Blu-Ray disc won't play on Samsung BD-P1600. It's Disney's "Tangled". I've updated the firmware. The disc loads so you see the Disney castle, and then it stops there. Well, the timer is...
Press the stop button on your controller when you get to the Disney castle, then press the disc menu button on your controller, this should take you to the disc menu and then you can choose play and watch the movie. This worked for me, I was having the same problem, even returned the Bluray disc, got a new one and same thing happened. The same problem is happening with the Tron bluray discs.
Apr 05, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Won't play new blue ray disk
Will your machine play standard movie DVD discs? if it does then the laser pickup assembly is the problem. The blue ray discs require a higher precision tracking to offer better resolution.
Dec 23, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I have a Sharp BD-Hp20 and i already got the firmware update and still cannot watch Avatar Bluray please help.
Make sure that you do have Version HU9071500 installed--->press setup button------>settings-------> version. If it is installed then after you insert Avatar it takes between 8 and 10 minutes before you can select play movie.
May 09, 2010 | Sharp AQUOS Blu-ray Disc Player
Blue ray disc want play in samsung bd p1600
Is your software up to date. If player has old software and you try playing some newer Blurays, it wont play.
Feb 03, 2010 | Samsung BD-P1600 Blu-ray Disc Player
DVD playback distorted in Samsung BD-P1600 Blu-ray Player
i had this problem with mine, found fingerprints on discs, just cleaned the discs and no problem after that.
Feb 01, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Netflix BluRay disc freezes on samsung 1600
I have had this problem a few times myself with clients players. A power down usually helps but only temporarily.
Check your firmware version and available product upgrade here: http://www.samsung.com/us/consumer/tv-video/blu-ray/blu-ray-players/BD-P1600/XAA/index.idx?pagetype=prd_detail&tab=support
Nov 24, 2009 | Televison & Video
Samsung BD-P1500 Blu-Ray Player Logo
492 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
