Question about Whirlpool Duet GHW9150P Front Load Washer
When its turned on makes a clicking sound the in
When its turned on makes a clicking sound the in the lighted area number comes up F 22
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F22 is a door lock error, this error occurs after the washer has made 6 attempts to lock the door. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
Testimonial: "Thankyou messed around the the door and lock area seems to be working just fine now. Let's keep our fingers crossed"
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
I have a Samsung 46" TV (LCD) which will not display a picture. The white light in the bottom center area lights up and the Red Light in the bottom right hand corner continues to blink. Finally, about...
had a totally knackered Samsung power supply which had to be replaced when I fitted new psu had clicking coming from new psu which turned out to be a faulty relay on the new Samsung p.s.u replacing the relay on the new power supply board got the TV working 100%
Mar 26, 2015 | Samsung Televison & Video
Grinding noise when its in nuetral with engine running
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make grinding noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Isuzu Pickup
I have a 02 passat when I start If up it sound like a truck. What do you think it can be. Its not turbo it just started doing it
There is N-number of possibilities for the car to make loud truck noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
My eclipse spyder 03 started making that noise like a week ago on the drivers side ? Anybody help plz!!!!
There is N-number of possibilities for the car to make whining noise or any other kind of noise.
These will help.
Thanks.
My 2004 t&c 3.8 is making a weird sound like a
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
These will help.
Thanks.
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Whirlpool Duet GHW9150P Front Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De
