Question about Whirlpool ACC108PS Air Conditioner
Coils freeze up
I have a Whirlpool window air conditioner (model #ACM102XKO) and the coils periodically freeze up. What can be done to correct this problem?
    Guru:
  • 587 Answers
Make sure blower is running at the proper speed, if it's running to slow do to bad bearing or capacitor, the coil will freeze up.
Check evaporator coil and filter to see if they are dirty if they are then the coil will freeze up
Check the charge if it's low on refrigerant the coil will freeze up.
If your not sure how to check these things, then you should have a HVAC company, check it out for you.
Posted on Jun 04, 2010
Testimonial: "The comments were excellent, however, since I do not know how to checkout the suggestions, I need to have it serviced by a repair person, or I might just be forced to go buy a new one. Thanks."
Coils freeze and temp says it is 55
Low on refrigerant or low airflow. The temp sensor is reading the ice.
Jul 20, 2012 | Whirlpool Heating & Cooling
If i set the temp to low on my window air conditioner can it cause the unit to freeze up
Under some conditions, it could freeze up. High humidity levels can cause the coils to freeze. Not cleaning the air intake filter regularly, can also cause the coils to freeze. However, most window units can not be set below 65 degrees. But, in high humidity, it could freeze at that temp.
If you want to avoid the possibility of the coils freezing, operate a ceiling fan or other small fan as fast as comfortable. This keeps the cool air moving a generates a wind chill that fools your body into thinking it's cooler than it really is. Doing this will keep you from having to turn the AC way down and thus, save on energy cost.
I hope this has helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
Our Gibson window unit air conditioner seems to be continually freezing up, i.e., the coils freeze up....... Only soution seems to be to turn it to fan only for awhile and then turn it back...
it needs to be cleaned when the coils get dirty it restrict it and makes it seem low on freon clean coils and filter please give we a vote or rateing
Sep 14, 2010 | Gibson Thru-Wall/Window Air Conditioner
Freezing up 8000 btu window unit
Coils may be dirty, filter may be dirty, water not draining or low on freon.
Jul 25, 2010 | Whirlpool Electronic Window Air...
Cooling fins surrounding coils are freezing and
mcdevito75 here, Possibly, the filter needs cleaning / replacement, unit set to too cold. Shut A/C off, let the ice melt on it"s own DO NOT REMOVE ICE YOURSELF, those coils have the fren gas in them, when the ice is all melted restart unit, set temp. not so cold, around 60--65 degrees, and have exhaust to out. This shpoul;d help, you can always check with your local A/C repair shop, they come to the house.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Air conditioner is freezing/icing up inside
needs to be taken apart and clenaned
Jun 21, 2009 | Heating & Cooling
Fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
Whirlpool Heat and Air Window Unit ACE184XRO- freezing up
This is only low freon. If the bottom coils freezes and frost over, you don't have enough freon to travel as liquid back to the compressor and boils right there and past this only cool gas .I'll advise you to get this fixed before you loose a compressor due to locking up by not cooling the compressor properly. Get in touch with an Ac man. this should only cost around $100:00
Sep 05, 2008 | Whirlpool ACE244XS Air Conditioner
Whirlpool ACC108PS Air Conditioner Logo
519 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
