Question about Maytag MDE2300 Electric Dryer
Dryer not heating
I checked the electric and cleaned the vent
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer not heating - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is ..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gifDryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 04, 2010
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer wont heat up
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Apr 08, 2014 | Samsung DV448AEE Electric Dryer
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Ge ds4500eboww
Pull off exhaust vent. Clean. Remove back cover. Clean all airways free of lint and debris. Is this electric or gas dryer? If electric, plug back in and run dryer. Is the heating element glow red? Yes, check and make sure that air is now flowing freely out the back of the exhaust vent. No, replace heating element.
Jan 11, 2014 | Dryers
The dryer runs but there's no heat. The vent is clean from the dryer to the outside vent and the heat settings on the control panel were checked and correct.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\[
Jul 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Takes about 5 hours to dry a load towels ????
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | GE DWSR405EBWW Electric Dryer
Dryer will not get hot. All the vents are clean.
Check for burnt out heating element and electrical connections to element and thermostats. If okay check all thermostats, operating and high limit, with an ohm meter. All must be in closed position. If element,thermostats,and electrical connections good then check timer.
Mar 21, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
