Question about Sharp R-520LK Microwave Oven
Model 520lk.can set time colck works, when start is pressed light come on; clock counts down but microwave does not start and turn table does not turn.
  • Sharp Master
  • 3,247 Answers
The microwave oven has got a couple of safety components to protect it and the people from harm. One is an interlock switch to prevent it starting if door is not properly closed. The other is a thermal fuse which blows if the oven becomes too hot.
In your case it is likely the thermal fuse is blown. This prevents the oven turntable, fan and the magnetron (the main microwave generator) from starting.
You can find the details in the service manual
http://207.234.249.73/mwd/r520lk_r520lw_sm.pdf
But I would not recommend you to fix it yourself if you are not familiar with electrical gadgets, especially the micorwave because it is unsafe and has very high voltage.
Please post a comment to confirm you have understood my solution to your problem.
Posted on Jun 03, 2010
Why does our new microwave not work? Can set the time and it counts down when we have pressed start but does nothing else.
There is a big fuse inside that thing. Check to see that it is not open. Could be that the magnetron, lite, and dish are all on the same circuit.
Sep 21, 2015 | Daewoo KOR6N9RR Microwave Oven
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Is there a fuse in the system? the light and count down function but no heating.
there are fuses in your microwave but they dont normaly blow unless there is another fault,
the fuses are not the normal house size fuses and are quick and slow blow types plus a high voltage fuse,
Nov 04, 2010 | Sharp R-520LK Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Sharp R-520LK Microwave Oven Logo
100 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
