Question about Sony Handycam DCR-TRV250 Digital Camcorder
C:31:23 blinking on my sony handycam - Sony Handycam DCR-TRV250 Digital Camcorder
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code C31:23 means that the FWD back tension value is too high due to grease sticking out of the "Gear Assy, Gooseneck", adhering to the band of "TG2, Arm Assy" or "Table Assy, Reel”. First remove all batteries and then shake the camera hard (or alternatively hit the bottom hard with your hand -at your own risk-), this will remove the error. If it still does not then you have to give the camera a couple of hard taps, on the side and base. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
  • 2 more comments
  • ihatesonynow Apr 27, 2011
    thank you that helped to bad after 15 years sony has finally lost me as a customer after not being able to give me advice to fix their piece of s**t product
  • mark_studer Jun 05, 2011
    It worked!!!! Let's just hope that does the trick and I can finally get all these tapes downloaded!
    Thanks!
  • emily121805 Jul 09, 2011
    Worked for me! Thanks!
  • jane marie boza Sep 06, 2012
    Yay! Now my camera is working again! : ) Thank you!!!!
  • 10,594 Answers
Yes, complete details are available HERE
Credit should go where it is due.
By the way, above info are for MiniDV camcorder (its mentioned in above link) and DCR-TRV250 is Digital-8 camcorder.
Posted on Jun 04, 2010
SOURCE: error code c:31:23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Posted on Mar 28, 2009
SOURCE: Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Posted on Aug 03, 2008
welcomejee
  • 10594 Answers
SOURCE: C:31:23 DCR-HC15E
Tape mechanism of DCR-HC15E camcorder is worn out, contact nearest Sony service center for mechanism replacement.
Posted on Mar 27, 2009
  • 586 Answers
SOURCE: flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: c:31:23
Check this
http://www.youtube.com/watch?v=VUIN-ygjN_g
this fix you problem
Posted on Jun 12, 2010
Sony Handycam 70x taking too long to import viideo to windows 7 OS
if it is taking 2 hours to import ( download ) then there is something wrong
23 mb should take 10 minutes at most
read the user manual for the cam operation , trouble shoot section slow download
May 07, 2017 | Sony Handycam Video Cameras
Sony Handycam DCR-SR200 e:91:01 means?
From page 32 of the user manual that is available for download here: (click here)
The error message that you are seeing requires that you to take the camera in for service, since a failure has occurred that the owner cannot fix themselves:
E:20:ss / E:31:ss / E:61:ss / E:62:ss / E:91:ss / E:94:ss
A malfunction that you cannot service has occurred. Contact your Sony dealer or local authorized Sony service facility. Inform them of the 5-digit code, which starts from E
Nov 26, 2011 | Sony Handycam DCR-SR200 Camcorder
I have a sony handycam DCR-SX40. The focus is not working. You can't zoom in or out. There is also a blinking E:61:10 on the screen. Thanks Jodi
E:61:10
A malfuction that you can not service has occurred. Contact your Sony dealer or local authorized Sony service facitily. Inform them of the 5-digit code, which starts from "E"
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRSR40
Download the Operating Instructions under the "manual" heading
Mar 07, 2011 | Sony Handycam DCR-SR40 Camcorder
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
Jan 19, 2011 | Sony Handycam HDR-XR520 High Definition...
Battery symbol blinking when put on charging.
It does sound like the battery needs to be replaced, but it also could be an internal charging problem with the camcorder. I would try a new battery first, since it's the easiest and cheapest option
Oct 19, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Problems
you need to have the head cleaned.
Sep 24, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony Handycam DCR-TRV250 Digital Camcorder Logo
1,723 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
