Question about Jenn-Air JES9800A Electric Kitchen Range
Jenn Air Electric Smoothtop Downdraft says "Power Loss"
Jenn-Air JES9800 BAS display says "Power Loss"
5 Suggested Answers
yalmer
  • 549 Answers
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Posted on Mar 17, 2008
  • 3 Answers
SOURCE: Jenn-air JES9800 error code F1-7
I got an f1 code in addition to a f9 ..Check out the f9 solution ..it worked for me..joe
Posted on May 28, 2008
SOURCE: outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Posted on Dec 09, 2008
yecalam13
  • 41 Answers
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Posted on Jul 24, 2009
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
How do you reset the clock
turn off probe light and beeping noise on Jennaire JES9800 how can I fix this
Nov 02, 2009 | Jenn-Air JES9860 Electric Kitchen Range
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Feb 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9800A Electric Kitchen Range Logo
338 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
