Question about Baxter BXA2G Stainless Steel Gas Single Oven
1985 Baxter 30 tray- Oven is set at 496F, oven reaches 460F and shuts down. Relights only after turning off and back on. What would cause this issue?
Replace high limit, check if the vents are dirty (bottom right and left circlular holes covered in "chicken wire" they could clogged , they are the air intake for the burner , also clean back of the green mixing valves
Posted on Nov 24, 2010
  • 106 Answers
The High limit protection thermostart could be wrongly positioned or faulty
Posted on Jun 15, 2010
Baxter revolving tray oven chain questions. I have a few questions below. Thank You
Slack is necessary to prevent early failure of the bearings on the wheels. It is also necessary for proper operation when the oven heats up. slack shouldn't be too much or the chain may fall off the teeth. Too tight and you have wear. The abrupt stopping indicates the need for lubrication of the motor.
Nov 09, 2017 | Baxter Ovens
Baxter ov500 keeps shutting off when turning on and eventually it will stay on
presume its an electronic gas oven.
on the main burner in the bottom of the oven (you might need a screw driver to remove the lower cover inside the oven) you will see a spark plug that makes the spark for ignition and you will see what looks like a bent bit of wire that is in the flame when its on. the bit of wire is the flame sensor. check that it is in the flame and hasn't moved. also give it a clean with a bit of fine steel wool to remove any carbon that might have built up on the flame sensor.
also here is a link to a free manual down load.
http://www.bakeryequipment.net/Baxter_OV500_Series_Rack_Oven_Manual_p/ov500ge.htm
Sep 22, 2016 | Baxter Ovens
Need to set clock for daylight time on baxter oven ov300e
With the oven on hold the time up or down arrows until the time begins to change.
Nov 07, 2010 | Baxter OV300E Stainless Steel Electric...
Burners will not stay on until set temperature is reached they shut off and on eratically....please help...
Have you tried cleaning your flame sensor? The little metal rod at the bottom of the burner can be removed and the metal rod that sits in the flame should be cleaned with a wire brush or emory cloth (fine sandpaper).
Sep 30, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Uneven cooking. how to adjust vents
Bend fins outwards to decrease airflow towards center of oven, bend fins inwards to increase airflow towards center of oven. Open gaps to increase airflow to an entire tray, close gaps to reduce airflow to an entire tray.
Only make small adjustments, trial and error may be required.
Sep 09, 2010 | Baxter BXA2G Stainless Steel Gas Single...
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
How do you change clock time? Hours,minutes,etc
With the oven on hold the up or down arrows to the right of the clock display until you've reached the correct time.
Oct 11, 2009 | Baxter OV300E Stainless Steel Electric...
Baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
Baxter BXA2G Stainless Steel Gas Single Oven Logo
352 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
