Question about Acer Aspire One PC Notebook
My KAV60 overheats when I am using it on a flat desktop. Are there fan problems?
  • 192 Answers
If you have lost the rubber feet that normally elevate the laptop off the table then yes, the flat desktop is restricting airflow to the unit. Place your hand next to the fan output and see if you feel warm air.. it will be faint as the fan in a laptop is not huge. if there is no air coming lift the laptop off the desk and see if the air flow improves if so then the desktop is your culprit. You should look at some type of cooling pad such as Targus makes that has supplemental cooling. Second possibility is that cooling fan and heat sink is clogged with dust and dirt. I have seen them so dirty they actually look like sponges where the dust bunny has formed in the shape of the laptop case area. Take a home vacuum hose if you have one, with the nozzle shielded with your hand to control the suction force and gently go over the exhaust vent on your laptop. Stay away from keys as the suction will pull them off keyboard. Do not allow full force suction on laptop or use a shop vac as they can cause damage. This will help clear out dust and clogging dirt that can affect cooling as well. If all of the above fail then you should look at a possible CPU or motherboard failure causing heat problems.
Posted on Jun 03, 2010
  • donprice459 Jun 04, 2010
    Also wanted to add
    The Aspire One system labeled with the model KAV60 is actually an Aspire One AOD250.
    Any information will be listed under AOD250, rather than KAV60 on the internet.
My ibm thick pad laptop suddenlly off every time i on it what might be the problem
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.A laptop fan assistedcooling pad may solve your problem
Mar 21, 2012 | Computers & Internet
Cutting out windows
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.A laptop fanassisted cooling pad may solve your problem
Mar 18, 2012 | Computers & Internet
Cpu overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 25, 2012 | Gateway GT5012 PC Desktop
Fans are not working in desktop
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 07, 2012 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My computer dell gx 620 desktop fan is running fast and it keeps on restarting and hanging especiall during heavy games and also videos and the fan is running fast
Aug 30, 2011 | Dell OptiPlex GX620 PC Desktop
Last shutdown due to thermal event
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Jul 15, 2011 | Dell OptiPlex 360 Desktop Computer
Mmy sony vaio VGC-JS270J desktop's fan is not working and in turn making my computer to overheat and shut down periodically
Ok, to open the pc, using a small screwdriver, remove the 14 square plastic/rubber bungs from the back of the case. this will expose the screws holding it together. Lay the pc screen - down on a soft, flat surface like a towel on a table. Undo all the screws and lift the back panel away this should give you access to the inner workings. Make sure you earth the pc by plugging - in the power cable but not switching it on. you should be able to get at the fan without too much trouble. if it is a moulded fan designed to fit only that pc, get the model number, if it is just a standard square framed fan, just measure it. You should be able to get a replacement fan from ebay for not a lot of money.
Give the case a good clean before re-assembling it (compressed air works best).
Good luck.
Apr 05, 2011 | Sony VAIO VGC-JS270J/Q PC Desktop
1989 Mazda B2600i pickup overheats. Replaced
you just said it you need a new fan clutch
Mar 20, 2009 | 1988 Mazda B2600 Cab Plus
Acer aspire 7720-6155 overheats and shuts off under moderate use.
Check to see if the fan is working, if not replace it.
If the fan is working and spinning freely, then clean the vents and remove any dust/lint.
You may need to remove the fan/heatsink off the CPU and clean off the old heatsink compound and replace it with fresh heatsink compound and reinstall the fan/heatsink.
When using the laptop, make sure it is on a firm flat surface and none of the vents are obstructed.
Jan 07, 2009 | Acer Aspire 7720 Notebook
Overheating problems
This is common with laptops if you use programs that use power. The notebook gets hot when the processor and hard drive are working hard. You are doing the right thing with the fan. They make coolers that go underneath the laptop that have fans for this reason. Check out this link.The link will explain everything. Never use your laptop on a flat surface. If you can find a cooler that is curved you are better off. Walmart has a good one. Also take everything apart that you can and blow it OUT. (Use a vacuum with a plastic hose if possible.)
Please rate this as a Fixya since I explained everything. This will keep my name near the top of the page. Thanks and enjoy your laptop.
Jun 22, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
