Question about RIM BlackBerry Bold 9000 Smartphone
My blackberry bold ringer is not working. no sound
  • 846 Answers
You speaker needs to be replaced. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an Blackberry Repair Guide that shows how to open a Blackberry. If you want somebody else to do it for you go to Blackberry Repair.
Posted on Jun 06, 2010
5 Suggested Answers
SOURCE: blackberry bold 9000 speakerphone doesn't work!
webburst has it right. I have same issue. if I squeeze the phone at the top the speakerphone works great. plastic spacer or webbursts solution above will works great.
Posted on Aug 21, 2010
SOURCE: My blackberry bold speaker power loss
open the back cover, there is a white soft thing under the flash cover. push it a little bit with a tooth pick or a sharp knife, it should increase the volume dramatically.
Posted on Jul 01, 2009
fleshgear
  • 541 Answers
SOURCE: blackberry bold volume fades and I can not here
go to profiles and change and enable the tone for ringtones
Posted on Nov 10, 2009
SOURCE: ringer is marked as off
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Posted on Feb 08, 2011
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
My problem is ringer volume i cant when someone is calling
Hi, when a phone has a ringer volume problem, is either the ringer of the phone is weak and you can't hear when someone calls you or the volume of the ringer is yet at a very low level in sound.
You will need to check the volume settings of the phone if the volume is low so you can increase it to a high level.
If the setting of the volume is high, that means the ringer that a makes you hear when people call is weak and will need to be replaced.
Any further question or comment, you can pass it on as comment.
Take care.
Oct 14, 2010 | RIM BlackBerry Bold 9000 Smartphone
How do i get my mep code to unlock my phone
I dont know about others but 'unlockgenie' definetly works. It worked for my blackberry curve 8900.
Aug 11, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
My BlackBerry Bold 9000 speaker/ringer is not working. I could only use the vibrate profile in order to find out that I have a call.
ive had customers with same issue...try there, go to options, themes, press the app menu key and click on reset default theme and remove the battery for one full minute...tested if it doesnt work it might be the speaker thats stoped working
Mar 24, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry Bold Speaker problem.
yes it is an hardware problem,you need to replace the ringer and the speaker to enable you to hear music and ringer to work back
Jul 19, 2009 | Lands Phones
Bold speaker volume
check if there is any dust in the speaker
contact service center
Jun 30, 2009 | RIM BlackBerry Bold 9000 Smartphone
Jun 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
871 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
