Question about KitchenAid KEYS750LQ Electric Dryer
Drum won't turn
Kitchenaid dryer electric
  • 416 Answers
HAVE you tried turning it by hand? many times when you hear an electrical buzz coming from the machine and it still isnt turning, then it is either a motor going out, or your wall socket and or wiring is no longer cutting it. May times when a machine is ran on insufficient power it will work fine for a while, but eventually the motor will begin to burn itself up because the voltage peeks are only half that on a regular socket as compared to those connected to a breaker designed to run 240v equipment.
SO, if you do hear a buzzing sound, and rotating the drum by hand gets it going, (sometimes it will take a few minutes to get it to full speed) then you definately have too few AMPs going to your unit. Immediatly check the breaker box for the breaker controlling that part of the home. The breaker should atleast have two switches on it and be the size of two of the smallest breakers in your breaker box. (to get a good look, once you open the breaker box, there is another panel that lies flush with the breakers, remove it)
the breaker should look like this or it will be doubled up, where as the two outside wires should put out 240v
GOOD LUCK AND PLS RATE THIS POST!!!!! :D
Posted on Jun 03, 2010
KEYS750LQ0 dryer doesn't start it just hums when I push start
Check the belt. You may have to open the machine up to look. if the belt is ok turn the drum by hand and see if the motor pulley is also turning. While you are in there look for foreign objects that have wedged against the drum preventing it from turning.
Oct 09, 2012 | KitchenAid KEYS850LQ Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
Dryer will not start but light comes on, heats drum okay. The dryer heats, the light goes off when the door closes, checked the drum and the belt is okay. When the start button is pushed nothing happens.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Apr 30, 2010 | KitchenAid KEYS750LQ Electric Dryer
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
Dryer will not cycle
Replace the belt and all will work fine. The belt spins the drum
Feb 09, 2009 | KitchenAid KEYS700LQ Electric Dryer
KitchenAid KEYS750LQ Electric Dryer Logo
203 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
