Question about Garden
Adjusting the idle jets on a homelite super 2
    Brigadier General:
  • 4,088 Answers
'L' is the idle jet screw and 'H' is the full throttle screw. Make sure the air cleaner is not clogged. Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed up, but still 4 stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine keeps running. Hope this helps!
Posted on Jun 17, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelite super 2 carburetor
There should be a screw next to the carburetor, and by turning it you can adjust the idle speed.
Sep 29, 2013 | Garden
Fuel adjustment on a homelite chain saw ut 104002
Hi Alex Sachs
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Aug 21, 2012 | Homelite Garden
I have an old homelite super xl saw and what i need to know is the high and low adjustments as well as spark plug gap
For the high and low speed jets turn all the way in and turn counter clockwise 1 1/4 turns to start with and continue a bit more until the saw runs a max speed(go by ear) and idling speed(idle down enough so chain does not spin while finger off triger). For the spark plug gap, go about 20 thousands of an inch. I hope this helps you out.
Jul 15, 2011 | Homelite Garden
What is the high / low carburetor adjustments and the fuel mixture for the UT21566 Homelite trimmer
Hi dcheddy...
If you have tried to adjust them already then this should get it running...then do your final adjustment when the engine is warm.
Free Answer...Please take time to rate me
Jul 09, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite st100 string trimmer carb ajustment with one ajustment highe and lowl
Hi lloydlavalla...
Jun 07, 2011 | Homelite Garden
Homelite chainsaw model 4620c will not idle unless it is in the half choke position
If the jet screws have slot heads, set 'L' CCW about 1/2 turn more or less. If proper, the engine should idle fairly well, yet allow the engine to 'follow the throttle'. If the jet screws have 'D' heads, you will need to either make a 'D' head screwdriver, or take the saw to a service dealer for adjustment. If the chain is trying to turn after the above adjustment, set the idle speed screw CCW until the chain stops trying to turn. Hope this helps!
Oct 18, 2010 | Homelite Garden
I have an old Homelite XL chainsaw that still works but that could use some carburetor adjustment because it frequentlyshuts down between cuts. I do not have a manual and I did not see one listed. ...
The H jet needle should be set so that the engine will 4-stroke at full speed, but immediately 2-stroke when cutting. The L jet needle should be set so that the engine will 'follow the throttle', but idle fairly well. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Check the fuel lines for condition and the fuel filter, air cleaner, and muffler for plugging. Make sure the carburetor fasteners are tight. Hope this helps!
Sep 07, 2010 | Homelite Garden
Can't adjust carburator.
look on the carburetor. there will be 2 screws right beside eachother. one is an idle jet and the other is the main jet. if you want faster or slower idle speeds, adjust idle jet. if you want more power, adjust the main jet. you have to get them set just right . they might smoke a little bit because you are throwing more fuel to it which means you are getting a richer mix
May 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
Garden Logo
326 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
