Question about Casio Exilim EXS10BK Digital Camera
The ability to zoom in and out wont work and it will not reset
I have tried to reset this wont work, neither does leaving the battery out for 48 hour as was suggested !
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 04, 2010
Camera got wet and won't turn on
If it was fully immersed, there is probably little that can be done. If a minimal amount of water has penetrated it, you may be lucky - try placing it somewhere warm and leaving it for 48 hours to dry slowly, then try again. If this does not work, then it'll either be an expensive repair job, or a replacement on your household insurance.
I've had a further thought - the water may have shorted out the battery, so it may be worth trying with a replacement battery.
May 01, 2016 | Nikon Coolpix S3500 Digital Camera,...
Error Code C 21:00 continues to flash
Hi, ok now you hold your breath and follow the instructions.. 1. remove all the batteries including the tiny backup battery (usuall seen behind the screen) 2.then hit it very hard.. now insert the batteries and check .. if you dont belive read the link http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html all the best regards sreejith
Jul 13, 2007 | Sony Handycam DCR-TRV530 Digital Camcorder
How do i reset tablet if tablet is not turning on
Since you didn't mention the brand name, etc, I'm going to give you some basic instructions that hopefully will reset your tablet to at least get it turned on so that you can do a more in-depth troubleshoot.
You're going to have to drain the battery battery first of all, and even though you cannot turn the device on, just leave it be with the battery inserted for 24 to 48 hours. After that, you'll need to plug the tablet into a charger and allow it to charge for a full, normal cycle (4 to 8 hours, depending on your tablet.) After that, try turning the tablet on again.
If that doesn't work, remove the battery from your device for about 10 minutes and while the battery is removed, hold the power button down for 10 seconds. Replace the battery and try to turn the device on.
If the steps above don't work, then the best idea is to take it to a qualified repairperson for diagnosing the issue.
Mar 03, 2016 | Tablets & eReaders
I dropped my huband's archos 605 in a sink full of water. It was in the case that it came with. Took the battery off and laid both parts on a radiator, on low heat. Will it work again?
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Dec 09, 2009 | Archos 605 WiFi Digital Media Player
Sidekick Slide was dropped into water, worked for a while but now does not switch on.
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
Oct 17, 2009 | Motorola Mobility SIDEKICK SLIDE Cell...
I dropped my iPod classic 80GB. I dont think I got any water into it. It has been 3 days now. When I play my iPod the music coming through the head phones is fuzzy and interfeered. It also wont connect to...
Sep 07, 2009 | Apple iPod classic MP3 Player
Flip Video Camera Won't Start Up
Flip support helped me solve this problem. Their procedure is to take the batteries out of the camera and leave it sit for 48 hours. After 48 hours, put different batteries into the camera and turn it on. Your problem should be solved. It worked for me the first time and now I currently doing it for a second time. Waiting for 48 is no fun, but at least it works and fixing it is not expensive. No explanation was given to me about the problem.
Jun 30, 2009 | Pure Digital Flip Video Ultra Camcorder
MY BLACKBERRY moistened WATER IS A BIT ME YOU PLACE A HAIR DRYER TELEPHONE WORK THE LESS THE SCREEN IS DARK
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
Apr 12, 2009 | RIM BlackBerry 8800
Lens wont go back in once camera is turned off.
lens motor probably blew a SMT fuse when it got jammed. either take it apart and probe for an open fuse with a miltimeter and jump it with a blob of solder, or remove batteries for 48 hours and try again. Maybe a hard reset (no battery for 48 hours) can reset a shunt type protection.
Nov 15, 2008 | Pentax Optio S50 Digital Camera
Casio Exilim EXS10BK Digital Camera Logo
54 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
