Question about Apple iPod nano
Ipod 2gb will not reset i have tried menu/select then select play buttons but it still wont reset and run
  • 50 Answers
Check if it's locked, then try again
Posted on Jun 04, 2010
I don't know what happened but ipod does nothing. tried resetting (menu & select)(menu/select & select/play) not sure what else to do. plugged into computer and still nothing. please help
Welcome to Fixya
Try resetting the ipod by pressing the middle button and the menu button at the same time for 5 to 10 seconds. The ipod logo should appear after the reset has done.
Thank you for using FIxya!
Oct 02, 2011 | Apple iPod classic MP3 Player
My ipod Nano Middle button wont work. The wheel works fine, but i cant select anything with the select button. It was working 3 days ago, but now it wont work.
try resetting it by pressing the MENU and PLAY button simultaneously for a few seconds. that usually resolves common problems dealing with the clickwheel.
Jan 17, 2011 | Apple iPod nano
My ipod nano 2gb is frozen between main screen and now playing wont restart and wont show on computer
You need to reset it, just hold down the middle button and the "menu" button for about 7-8 seconds, or until the apple logo appears.
Hope this helps!
Sep 30, 2009 | Apple iPod nano
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
May 05, 2009 | Apple iPod nano 3rd Generation
Ipod wont play and games are gone
Try reseting the ipod.. Follow the steps and let me know the status
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 15, 2009 | Apple iPod nano
My ipod wont respond
Hey, simply reset your ipod
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Sep 04, 2008 | Apple iPod nano 3rd Generation
My Computer and iTunes does not recognize my iPod
Have you tried resetting it? Press the center (Select) button and the Menu button at the same time and hold for at least 10 seconds or until you see it reset.
hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Apple iPod nano
Apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 05, 2008 | Apple iPod nano
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod not playing songs
restore to factory setting using the software. that could help.
Nov 24, 2007 | Apple iPod nano
Apple iPod nano Logo
113 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
