Question about Traxxas T Maxx 3.3 Monster Truck
My t maxx 3.3 does not keep running - Traxxas T Maxx 3.3 Monster Truck
  • 56 Answers
Need more info, when does it cut out? If its cutting out when braking then youre idle screw will need to be turned clockwise a touch as this will prevent carb from closing and cutting engine.
Posted on Aug 09, 2010
Maxx heater lights all burners for aprox 20 sec blower fan starts flame goes out flame lights again for 20 sec never blows much heat ?
sounds like its not getting gas fast enough to keep burning,that happen to me and the gas line was to long of a run for enough gas keep coming. so I up the pipe runs real good the flame keeps burning, so you know you can only go 25 ft in half inch pipe then u lose your flame
Oct 24, 2014 | Mr. Heater Natural Gas Garage Heater -...
My New T-Maxx 3.3 wont start
Maibe the starter wassent charged all the way this happend with mine
Mar 22, 2013 | Traxxas T Maxx 3.3 Monster Truck
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
T maxx 3.3 will start rate up but will not run at all but if i pick it up all 4 tire's spinn like mad but when put down just sits there and runs and smokes but will not move HELP PLZ!!
Check to make sure you don't have a bad servo. When you pick it up the wheels will spin just do to the amount of power the little engine is putting out. Put when you pull the trigger do they go faster? If not then the check these
1. make sure your trims are set correctly on the remote
2. you are on the right frequency - usually there are 3 settings..frequency can be checked by making the tires move side to side also.
3. if you have the trim set right, and the right frequency then you may need to replace the servo
May 30, 2012 | Traxxas T Maxx 3.3 Monster Truck
My traxxas motor looses power after running for awhile
this happens to mine sometimes too. i have found that if you richen the high speed needle about a 1/4 turn it works fine. it will also keep your engine temp. down.
Jan 16, 2012 | Traxxas 4910 T-Maxx RC Monster Truck
What causes cooling fan to keep running when temperature gauge reads cool
possibley the ac is on the fan will run make sure the ac is off also stuck relay is possible or bad sensor good luk
Nov 28, 2010 | 2006 Chevrolet Malibu Maxx
Im having problems with my 05 maxx..... electrical???
I would get all the electrical schematics and then look for problems like blown fuses affecting the areas you are describing. Then systematically troubleshoot the wiring. Simple.
Now, I am looking for the mentioned schematics on the web. I just bought (2010-01-28) a 2005 Malibu Maxx, and can't wait to have it ready for pickup in 2 days...
Jan 09, 2010 | 2005 Chevrolet Malibu Maxx
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
I have a t-maxx it turns over slow have a new glow plug but it want fire it just keeps turning over its been sitting 4 a while. and getting gass to the carb. its the t-maxx 2.5r
Did you use any after run oil in the motor before it sat? The alcohol in the fuel causes condensation inside the motor if it is left with fuel in the motor. I normally spray WD-40 into the glow plug hole and into the carb and crank the motor for about 10 seconds. I do this 3 times and then do it once more with after run oil. The motor starts a lot easier after it has been sitting. You could try spraying some WD-40 into the motor and cranking it over. There could be some rust inside the motor.
Sep 20, 2009 | Traxxas Toys
WHATS THE NORMAL TEMPERATURE
that is fine. as long as it does not run past the 3/4 mark.
Jun 13, 2009 | 2005 Chevrolet Malibu Maxx
Traxxas T Maxx 3.3 Monster Truck Logo
651 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
