Question about Ryobi Garden
The petrol strimmer keeps lossing power and have to leave the choke on but still lossing power satrt ok then when tou sqeze the lever will go as long as u dont do it to hard but then will lose power
  • johnbutler65 Apr 25, 2012
    very sorry i didnt answer u i forgot that i asked it so so so sorry
4 Suggested Answers
moretons
  • 155 Answers
SOURCE: mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Posted on Jul 25, 2009
  • 474 Answers
SOURCE: petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Posted on Sep 14, 2009
hunter19_46m
  • 7482 Answers
SOURCE: EFCO petrol strimmer - can anyone tell me how to
If you need to clean the filter, remove it from the fuel tank and blow compressed air into it, otherwise you may have to do the following:
Sounds like you will need to clean your carburetor
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 24, 2010
Loss of power
May need to let warm up longer. You usually turn the choke on to start. You then need to turn it off to accelerate. If choke is automatic it needs to be cleaned/adjusted. It would also help to add a fuel system cleaner to your fuel.
Apr 20, 2016 | Garden
Sovereign strimmer HS-PT-2538
I had this problem once when machine was hot it was difficult to restart, I've found putting choke on slightly, about a quarter of the way, and not touching the throttle will see it starting, then put choke back off and leave it to idle for 20 - 30 seconds before using. Seems to be a characteristic of this strimmer.
Jun 11, 2013 | Garden
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
How to solve starting problem of royal enfield disel bike?
hi! dude this is viraj ,,, i also have a 97 taurus,,, there are 2 reasons that your bike will not satrt at the very first kick (1) is that check your clutch settings if the settings are loose than your kick will give a slip resulting in a low pressure kick which is not enough for startin the engine,,,(2) if your bikes cold and you keep kicking it you will have to pump a lot of energy in it your engine will fire only after 15 to 20 kicks .... there is a sollution to this ...PULL THE DECOMPRESS LEVER WHICH IS BELLOW THE TANK ON THE HEAD AT LEFT SIDE ( NOT THE CHOKE LEVER) AND PUMP YOUR BIKE ATLEAST FIVE TO SIX POWERFULLY WITHOUT LEAVING THE LEAVER..... AND NOW START THE BIKE AS YOU DO,,,
Mar 09, 2011 | 2000 Enfield Taurus diesel
How do I start a B&Q Petrol strimmer
IF IT HAS THE PRIME BUTTON.
press several times slowly. turn on/off switch to on. select full choke. pull starter until it tries to fire but no more than seven times. select half choke and do the same. if it fires up allow to tick over for a couple of miutes then open choke fully. if it doesnt fire leave for 10 miutes then start all over again. good luck
Aug 12, 2010 | Garden
Need new plastic primer for multi purpose strimmer
any good small engins shor should have tthem all both walbro and zama you nrrd to know the bdand and modl of thr m schine that needs ij
Oct 28, 2009 | Ryobi Garden
Mcculloch strimmer/brush cutter - cuts out when throttle opened
Jul 25, 2009 | Garden
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
Garden Logo
1,021 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
