Question about Refrigerators
A kitchen aid top freezer refrigerator model number ktrs22kbwh01. The freezer door does not close all the way. the gasket is still good. There's just a fraction of an inch at the bottom inside that rubs against the inside compartment of the freezer. Do I need a new hinge or washer or is there too much stuff inside the freezer door shelf? thanks Joel
  • 2,272 Answers
Lift the freezer door with your hand and then close the door and check out.Is the door closing properly.If its closing properly that means the hinge holding the door is got loose / worn out and needs replacement.But if the freezer door is proper tight and not getting any lift then its not the hinge problem.Then check the freezer door seal.Its in the inner-side border of the door.If the seal is got bulged up or its got misaligned from door frame then it can be the other reason.Also check the nuts and screws holding the hinges if the nut or screw is got bit loose then hinge will not hold the freezer door with proper grip.Most probably the problem is between hinges and door frame seal .But in some cases it has been noticed that door frame gets bit slight tilted and looses its alignment and this causes the problem.Also check for any other thing blocking the freezer door to get properly closed. For getting any required parts for your refrigerator you can get it from online sites like www.repairclinic.com or the another site is www.partsselect.com
Thanks.Keep updated for any further query.Rate the solution and show your appreciation.
Posted on Jun 03, 2010
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
GSH25JSTFSS FROSTING IN FREEZER
Hello Bob;
My name is Peter. I am a retired field service refrigeration technician.
Your problem is directly related to warm air due to low freezer temperature or outside war air getting into your freezer.
First, Check the freezer temperature. It should be set at -2 to +2 degrees F. If you can not control this temperature then you have a bad Bi-metal on the cooling coils.
Second, you have a spring release ice dispenser. Reach up and pull the door to open does it close completely? When you select the crushed ice option, pieces of the crushed ice will not clear the dispenser door and block it open, where warm outside air will get into your freezer causing a frosting problem.
Third, Door gasket not sealing. With a piece of paper, sun the paper completely around the door gasket and the face of the freezer. If you can move the paper around the door then you have a bad seal. Inspect the freezer door gasket for tears. No tears, Then with a hair dryer and a kitchen spatula, heat the door gasket one section at a time while using the spatula pulling out to expand the gasket. At times door gaskets will be come crushed and require reconditioning.
Fourth, Freezer door not completely closing. Often, I had gone on service calls for the same problem. The customer had the freezer so packed that it would not completely close. The customer had food going beyond the shelf edges. Or, a freezer door was stuck and not completely move in.
Fifth, Worn door cams. On the bottom of the door you have a set of door cams. These become worn. They are hard rubber. Laying on the floor, open and close the freezer door. You should hear a popping sound as these two cams engage and disengage. These cams lock the door in place.
Sixth, Refrigerator leveling. When your refrigerator is delivered it is leveled. This is wrong. Your refrigerator should be level from left to right, but the front off the refrigerator should be slightly higher to ensure by gravity the door will close by themselves and ensure a good seal.
Go into the following website and put in your model number. You will get both diagrams and component part numbers. Record the part number you may need and search the internet for best price.
Water Filters Lawn Garden Appliance Parts
Mar 16, 2016 | General Refrigerators
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Bottom freezer door opens when top door is open and then closed
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
Jul 02, 2009 | Refrigerators
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Kitchen aid top freezer is developing ice and refrigerator is not getting cold
well well looks like we have a defrost problem... either a board, defrost heater or timer or termination switch.... let me get the model number and we can get this fixed pretty easily... visit whirlpoolpartssurplus.com where you can reach me there ext 0.
Apr 27, 2009 | KitchenAid Architect KTLA19KRSS Stainless...
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer door pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
Mar 04, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
