Question about NAD 1020 Preamplifier
I have a Nad preamp 1020 A and the volume control dont work well. How can i get this part? Claude
  • 105 Answers
You dont need to replace it just open it put a drop or two of cleaning oil in volume control and it should work fine
Posted on Jun 04, 2010
NAD C162 preamp quiescent noise level suddenly went up. Please help me diagnose?
If the noise is in both channels then you should look for something common to both channels. Capacitors are the likely cause, but some IC's might cause it. You say that the volume control doesn't effect it, if that is the pre-amp's volume control then the fault will be after that part.
Oct 26, 2017 | NAD Audio Players & Recorders
Can you still get a new volume control pot for a nad 310 intergreated amplifier
I don't see why not. Just get the value of the pot off the numbers on the back of it or measure it
Aug 30, 2016 | NAD Audio Players & Recorders
How do you connect a nad c270 amp to the bose 901 series vi equlizer and system/
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the same amp. The reason is that the 901's require the use of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
For connection I would run a pair of RCA cables from the L&R Audio Line OUT of whatever preamp or source you're using to the Active EQ's Line IN; then the EQ's Line OUT to a NAD amp's Line IN. DEselect any Tape options on the Active EQ, attach the 901's to the new amp, set the NAD volume controls pretty high (and leave them alone), run through any level setup procedures in your control electronics for volume, etc and you're done.
Aug 17, 2010 | NAD C270 2-Channel Amplifier
Losing one channel, comes back if you move the volume switch around then goes again ?
That must be a dirty volume control (potmeter).
Or there's a lose contact on the PCB which is soldered to your volume control (potmeter).
regards,
Gerard
Mar 22, 2010 | NAD C370 2-Channel Amplifier
How do you connect power amp to av
I presume you want to use it to drive speakers from a source controlled by the Denon??? Probably the Front channels? We'll assume that's it...
Run RCA cables from the Pre Out jacks to the NAD's L and R inputs. If it has a volume control, set the NAD to its maximum volume (for consistency *), run through the setup for levels and you're done.
* If it doesn't have a volume control it's already set to max. That's normal for power amps. Your receiver / preamp controls the volume fed to them.
BTW: If you're thinking of using two sets of Front channel speakers simultaneously you'll have to choose a level on the NAD that will match up with the others in volume.
Jan 22, 2010 | Denon AVR-3805 Receiver
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
Hello, the volume pot on my NAD 1020 is shot and needs replacing. I know I can do this myself but I need to know the value of the pot. Thanks!
When you remove the pot there should be a series of numbers on it. Post those here and I'll decode them for you. These units varied based upon the serial number as well. If you can post the serial number, I will also confirm the value in the service manual for your unit. Thanks, Dan
Jun 06, 2009 | NAD Audio Players & Recorders
No volume control
lower the volume of the cd player
May 08, 2009 | NAD C320 2-Channel Amplifier
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
NAD 1020 Preamplifier Logo
231 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
