Question about Dishwashers
I have a brand new GE Profile Dishwasher model PDW9280N20SS . I clean most of the food off and lightly scrub the dishes. But any left on food is generally still there after the wash cycle. In addition, there is a light coating of some sort. I use Cascade and jet dry but am not very happy with the results thus far. Any thoughts??
  • Anonymous Oct 30, 2008
    I have the same problem. I just called the GE repair man to come and look at my dishwasher. He said everything looks fine--but the dishes are still dirty.
    We had already raised the temperature of the water to 130 first before we ever called the technician. The dishes are not getting clean.
    Genius:
  • 1,073 Answers
Make sure that the water temp coming into the machine is at least 130 f , i would start there first
Posted on Apr 10, 2008
Sometime there is a little dirty water left in the bottom and the dishes are dirty
Some models do not have a food grinder, only a food strainer to collect the larger chunks of food which may be partly blocked. the drain to the sink may be partly blocked.
Mar 02, 2016 | Dishwashers
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
Nov 10, 2013 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile Dishwasher Model pdw7880n10ss does not clean. Food sitcks to the dishes and food is at the bottom of the dishwasher when the cleaning is finished. It has not cleaned from day one. I have...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 02, 2011 | GE 24 in. Profile PDW7800 Built-in...
Our Ge profile Dishwasher is not cleaning the upper level dishes, mostly glasses and coffee cups. The insides are bumpy with dried on food. We have cleaned the bottom filter.
heatman101
Oct 24, 2010 | GE 24 in. Profile PDW7800 Built-in...
Soap (?) residue on dishes; also not getting them clean--food on
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
PDW9280N20SS Dish's are not being clean
heatman101
Apr 25, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
215 people viewed this question
Top Dishwashers Experts
