Question about GE 30 in. Profile JGP932 Gas Cooktop
Ge profile cook top snapping
My cook to igniters snap whenever they get moisture. e.g. when the humidity rises. I can stop it by using a hair dryer but it starts again after a few hours. How do I access them for repair or replacement?
  • GE Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
The igniter on my GE cooktop wont stop clicking, only if i unplug it.
Spark module part no 318 at parts diagram it may be wet and by using a hair dryer or leave it unplug for some days can dry out and stop. If not then the electric contacts are stuck and need a new spark module
Aug 27, 2011 | GE Profile JGP636 Gas Cooktop
When I try to use my gas cooktop, it makes a loud "pop" sound and has a big electrical spark that smells like fireworks then it flips the breaker.. Any ideas??
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hair
dryer do try it out and be sure there is not and liquid in it and put
electrical plug again to test it. If you still have the same problem, replace
the Spark module with a new one.
Here below you will find the
parts layout of your range for all the help you might need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
Dec 13, 2010 | GE 30 in.Profile JGP945 Gas Cooktop
After cleaning my cook top, the igniters won't stop clicking. What do I do?
The electrodes have moisture around them still and you can assist in them drying with a hair dryer or even turning the stove tops on for about 15 minutes to assist in drying them out. Don't go ordering parts you do not need. Thanks, Rick
Mar 09, 2010 | Cooktops
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
Ingiters don't work - all burners
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
Apr 27, 2008 | GE 30 in. JGP337 Gas Cooktop
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
GE 30 in. Profile JGP932 Gas Cooktop Logo
415 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
