Question about Kitchen Ranges
I have a smooth top electric stove that the oven has stopped working on. only the broiler works and 3 of the four eyes work on the top surface. can you please tell me what;s wrong with it and can my husband buy the parts to fix it it;s out of warranty, only had one years warranty. Thanks Silla
  • foxymahogany Jun 03, 2010
    still had more questions sent another question about how to do the things you accepted, thanks, Silla N
    President:
  • 1,561 Answers
Inspect the outlet into which the stove is plugged. The plug should fit into the outlet snug and secure but it may have loosened. Unplug the electric stove and plug it back in to be certain that a good connection has been made.
Examine the clock of your electric stove. If it does not show any time, the outlet should be checked.
Take a small lamp or other electric appliance you know works well and plug it into the outlet where you usually plug in the stove.
If the appliance does not work, the outlet is to blame and may need to be replaced.
Checking the oven settingTurn on the oven and set the temperature to 350 degrees F. Return after 10 minutes to check for any heat. If the oven does not heat up at all, turn it off.
Ensure that the oven portion of the electric stove has not inadvertently become set to the self cleaning cycle. Cancel the self-cleaning cycle and additionally undo any manual lock-out which may be set for the self cleaning cycle to start.
Check for a display that may indicate a delay mode. In the alternative, a cooking cycle may have become set and is therefore barring you from using the oven at this time. Examine the timer function and ensure that no cycle is currently programmed into the system of the electric stove. Most electric stoves offer the option of a manual timer override.
Push the button for the override and repeat steps 1 and 2. If neither the oven did not heat up, you have isolated the problem to be either the thermostat or the wiring.
Checking the thermostat and wiringLook for a bake selector switch. Unless your electric stove features this switch, it is controlled by a thermostat. Unplug the stove and troubleshoot the thermostat by adjusting it incrementally to hotter or higher temperature.
Turn on the oven and set the temperature once again to 350 degrees F. Return after 10 minutes to check for any heat. If the oven does not heat up at all, turn it off again.
Replace fuse and retest the operation of the electric stove.
This should fix the problem on your electric stove and it should work fine.
Take care.
Posted on Jun 03, 2010
    how do you overide the bake cycle or the self cleaning cycle, or how do you find where the fuse is on the stove? the broiler works but when you push bake on the bake button on the stove, the 350 comes up,but it goes off after a minute or two, but the oven doesn't bake. also if i hit the keep warm button that stays on and i can broil hamburgers, but, the botton part of the oven doesn't work . please help. Thanks. Silla N
The GE Range stove top is working fine, but why won't the oven or broiler work?
Electric or gas? Does make a difference.
U want assistance but you are not making it easy.
Feb 12, 2016 | GE Kitchen Ranges
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed ' http://www.atlasappliances.com
Aug 19, 2014 | Kitchen Ranges
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
