Question about Mr. Coffee AD4-2 Coffee Maker
Cleaning what is the best way to clean this coffee maker?
How do I clean my mr. coffee?
Posted on Jun 16, 2010
Clean light
The best bet is to contact the company on line and seek the instruction manual for that machine. Usually, the fix is in the back of the manual.
Mar 25, 2014 | Mr. Coffee 072179228578 12 Cup Coffee...
How to best clean the coffee maker?
I run a cup of Distilled White Vinegar mixed with water through my coffee maker about once every two weeks.
Apr 21, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Best way to clean the coffee maker
Just clean it with Hot water... let it run without adding coffee to it, just plain water...
May 08, 2010 | Oster 10 Cups Coffee Maker Model 3297-053...
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
Apr 13, 2010 | Bunn VPR Coffee Maker
Keeps flashing CLN after cleaning
i had this problem
if u have hard water and do a fresh clean but it dosnt clean it well then it will flash clean time time again
best soultion to clean if u havnt tried it is
Pure Vinegar white..
run through 2 times then clean with water 2 times then ur problem surely will be fixed .. if not hit me up
at
peterjw@bell.net
and ill have more information for you..
best luck
Oct 26, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker works very slowly after about three weeks of use. Specifically, the water does not pass through the filter and into the pot quickly, if at all. Suggestions?
Try cleaning it with white vinegar. Put in one cup with a potful of water, and let it soak. To get more cleaning, pour the water/vinegar through again, hot. Put in a coffee filter to catch/strain the debris, and you will be able to see if it's helping. When you're through cleaning, pass fresh water through the machine by potfuls, until no traces of vinegar can be detected.
Best regards, --W/D--
Aug 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
How to clean my cuisinart coffee maker - (can't locate manual) there is a clean button but if I just push it nothing seems to happen
Here's a link to Cuisinart where you can download a free copy of your user's manual. Just download and print a copy for your use and future reference. It contains all the info about your unit and how to use the cleaning function.
http://www.cuisinart.com/share/pdf/manuals/dcc-2200.pdf
Hope you found this very helpful and best regards!
Aug 06, 2009 | Cuisinart DCC-2200 14-Cup Coffee Maker
What is the best way to clean the cuisnart coffee maker
white vinegar will leave the least amount of odor,and can be run through the entire unit safely, just remove the filter part if it is metal. and is non toxic.
Household comet or bleach will completely clean the carafe, and outside parts, however you must rinse COMPLETELY. before use as these are toxic chemicals and should not be ingested.
Never mix chemicals.
Jun 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Mr. Coffee AD4-2 Coffee Maker Logo
172 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
