Le19lcd0703 my 19'' lcd has stopped working. when turned on the red lcd light flashes continuously. what does this mean?
    Problem Solver:
  • 18 Answers
This means:
Press the power button for 30. You tv will return to normal.
If that doesn't work unplug for 2 mins.
Posted on Jun 03, 2010
My Sony bravio flat screen tries to turn on and then turns off and the red light flashes continually.
If it is the type that uses a main light bulb (i.e. ''DLP''), it means the bulb is bad.
If it is an LCD (or Plasma), then it is likely a bad power board.
May 18, 2015 | Sony BRAVIA Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
RED LIGHT WONT STOP FLASHING
shellnbarry, The red light flashes when an ink cartridge is low (but not empty). You can continue to use the printer until the red light stays on meaning an ink cartridge is empty.
Nov 12, 2009 | Epson Stylus C60 InkJet Printer
EPSON C60 RED LIGHT FLASHING ON CENTRE BUTTON CANT STOP IT
shellnbarry, As I stated in a previous post the red light flashing means an ink cartrdge is low but not empty. When the red light stays on it means an ink cartridge is empty. You can continue to use the printer until the red light stays on.
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
