Question about T-Mobile Samsung SGH-i900 OMNIA mit 16GB internen Speicher Cell Phone
Bypass align screen it is caught in a loop everytime I reboot the phone
I RESET MY OMNIA I900 AND NOW ONLY APPEAR "ALIGN SCREEN"
Posted on Jun 24, 2010
Forgotten number pin
If you just need temp access and you can log into the google account associated with phone. Then you can: (With phone on) go to play.google.com from a pc. log in. and search for lock screen bypass. select your device and choose install. give it a few minutes to complete. reboot phone and wait for a bit and you will see the screen lock bypass app show up. click add admin account. sometimes it will throw you back to lock. just reboot and do it again. once you are at screen lock bypass app after adding admin account press BACK (pressing home will usually result in lock screen). And when you first boot phone its good to wait at least 2 - 3 minutes before pressing back to home screen. (I see better result and less lockscreen hiccups.) once you are finished you can reboot phone again and when bypass pops up you can uninstall from there. While in backup your data and do a factory data reset afterwords to get back into your phone properly.
Nov 29, 2013 | LG Optimus Black Smartphone
Hp all in one printer - printer head alignment problem
Try pressing the reset or off button for a few seconds. Failing that, unplug the printer for 15 min. Let me know if it works, if not, then I will guide you through other steps.
Nov 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Bt vision problems
When I have had this problem in the past a hard reboot has solved the problem. Suggest you try pulling the power and restart. You may want to make sure it's not wrighting to the disc at the time as this may give you a problem though so try powering it off with the power switch rather than pulling the power from the back first, but if it's caught in a loop you may have no option.
Nov 18, 2013 | Video Game Consoles & Games
Crack password for android
if you just need temp access and you can log into the google account associated with phone. Then you can: (With phone on) go to play.google.com from a pc. log in. and search for lock screen bypass. select your device and choose install. give it a few minutes to complete. reboot phone and wait for a bit and you will see the screen lock bypass app show up. click add admin account. sometimes it will throw you back to lock. just reboot and do it again. once you are at screen lock bypass app after adding admin account press BACK (pressing home will usually result in lock screen). And when you first boot phone its good to wait at least 2 - 3 minutes before pressing back to home screen. (I see better result and less lockscreen hiccups.) once you are finished you can reboot phone again and when bypass pops up you can uninstall from there. While in backup your data and do a factory data reset afterwords to get back into your phone properly.
Jul 27, 2012 | Android Huawei
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
May 29, 2009 | Palm Treo 755p Smartphone
Ati2dvag caught in a loop
ati2dvag seems to have a problem with XP SP3
I don't know if you have SP3, but if you do, try rolling back to SP2
Method 1: Use the "Add or Remove Programs" item in Control Panel
1. Open the Control Panel
2. Select Add Remove Programs
3. Click to select the Show Updates check box.
4. Click Windows XP Service Pack 3, and then click Remove.
5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder
1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore and select a restore point prior to SP3
Oct 05, 2008 | Toshiba Satellite A105 Notebook
Axim X5 Align Screen Loop
I am by no means an expert but I have had the same problem that you are having and I found that after I took my X5 apart and cleaned around the underside edge of the plastic housing frame that was at the edge of the screen the problem went away. I also cleaned the front of the screen very well and put a new back-up battery in. I have not had the problem since.
Sep 05, 2007 | Dell Axim X5 Pocket PC
T-Mobile Samsung SGH-i900 OMNIA mit 16GB internen Speicher Cell Phone Logo
923 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
