Question about iLO 3200 32 in. LCD Television
I HAVE GOT A NEW DIGTEL CABLE BOX AN I CAN'T PROGRAM IT BECAUSE I HAVE NO CODE TO MATCH IT WHAT CAN I DO
  • 530 Answers
Please respond back with the make and model of all the equipment. Thanks.
Posted on Jun 03, 2010
Need the five digit code for the cisco cable box model 4642hdc to program my tv remote
I have vizio 42 LCD I need the five digit code for the cisco cable box model 4642hdc to program my tv remote
Jan 26, 2011 | Televison & Video
Need to program a new remote for RCA TV
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
Aug 24, 2009 | RCA Universal Remote Control
Cable converter box - video not matching audio
SAP secondary audio program is activated .it has to be turned off with the menu controls
Aug 19, 2009 | Televison & Video
Can get dvd/vcr to work but vcr won't record
first did you program the vcr to match your cable channels ...that needs to be done on most vcrs/dvd/ combos and second if you have a cable box on your tv you still need to run a coax cable from the cable box to the in of the dvd player and out of the dvd player to the tv.
May 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Cadge cluster
call junkyards for a new 1. had the same prob n had to b replaced
May 12, 2009 | 1994 GMC Jimmy
Need to program a universal remote to work on Magnavox TB100MW9
Most of these are new and codes do not exist for them. You'll need a universal remote that has a learning feature so it will learn the code. Walmart has them for $16-$19.
Nov 11, 2008 | Philips Magnavox 27MS343S 27" TV
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Jul 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Programming remote?
on your remote try pressing enter and then the #3 this should program the remote to match the dvd player. It worked for me last night.
May 01, 2008 | Sony RDR-VX525 DVD Recorder/VCR
iLO 3200 32 in. LCD Television Logo
123 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
