Question about Garden
Is there a way to seal rotting plywood so the rot won't progress any further? Or even after a waterproof sealant, it will still continue to rot and disintegrate? thanks!
  • cbalis7 Jun 03, 2010
    thanks, that was very helpful and thorough!
  • 843 Answers
No. The problem is that the waterproofing has to act as a barrier between dry good wood and any rot or dampness. There is no way that a sealer will be able to penetrate to the middle of the board where that boundary currenlty is. And even if it could, the area where it is soggy will continue to degrade until it falls apart. And if you could apply some kind of fungicide to soak in and kill the rot, it wouldn't do anything to heal or dry out the rot you already have. The only partial method is to cut out the bad areas and replace them. Or if a very temporary solution is needed, you can put another layer on top - but that won't stop the rot or the mildew.
Posted on Jun 03, 2010
How do I level a floor?
that should have been looked at before the durarock and plywood were put down the floor joists might be rotted off on the ends only a local contractor can give you a cost estimate
Feb 22, 2016 | Building Materials
How can I replace worn out grease seals on entire front and rear suspension system?
Check out ebay. I bought a whole selection of track rod style boots in a bag for which you select the appropriate size for your torn/rotted boot. Maybe someone does grease seals. I take it you've been to the dealer to see if the seal is a separate part number?
Nov 05, 2015 | 2003 Lincoln LS
Screw loose in securing toilet to flange
Hopefully you can tighten it Sometimes the flange bends up or can break. Many a flange is not held down properly with good enough screws or the plywood has been rotting etc. If you can tighten it or loosen it then it has to be cut off with a recipricating saw or hacksaw and replaced.
Nov 29, 2013 | Kohler Toilet - One Piece with Ingenium...
Why do my tires on my car loose air overnight?
There are multiple possibilities...
1. There are punctures in the tires.
2. The valve stems are rotting and leak air.
3. The tire sidewalls are dry rotted and leaky
4. The rims have rust or debris on the bead preventing a good seal
5. The tires were installed improperly, damaging the bead.
6. Someone is letting the air out.
Nov 13, 2013 | Cars & Trucks
Bathroom floor rot
take up the floor. lay new underlayment ( I recommend concrete wall board at lumber yard), then add top surface (ceramic, linoleum, wood)
good luck
Neil
Nov 09, 2013 | ProteShield 1-Gal. Elastomeric Waterproof...
Ceiling repair after a water leak
To start you have to find the leak in the roofing. Then repair the leak . Then what kind of ceiling material is it ?? Sheet rock, wood, plywood, tung and grove , tiles ????? need that info first and second how big of an area rotted????
Aug 13, 2013 | Televison & Video
Food rotted in our refridgerator and the smell is in the seal can the seal be replaced or taken off to clean
should come off if it is not glued. it is secured in a groove or has little knobs that stick in holes, you can tell if you just pull it away a little. wash it with bleach/water really good, along with the fridge interior. the odor will go away!
Oct 15, 2012 | Dometic NDR 1292 Refrigerator
Muffler is rotting were it connects with the exhaust pipe what is a quick repair?
Some muffler shops use a metal wrapping that might work depending on the area that is rotting. Also you can try some JB Weld but not sure if the metal is in good enough shape to bond. You might have to replace the muffler if it won't seal and bond over the rotting metal.
Oct 12, 2012 | 1998 Hyundai Tiburon
How can I keep my outdoor wooden bar stools from rotting?
You should seal the stools with a water sealant at least once a year. After rain/morning dew/humidity, make sure to wipe moisture from your bar stools with a lint-free cloth. When not in use, cover your bar stools with a protective cover to ensure longevity.
Jul 24, 2012 | Furniture
1995 Jeep Grand Cherokee Laredo - sunroof leak
lift rubber edges and apply clear silicon sealant under edges let cure hose with water to test, if leak then seal edges of glass with eurothane sealant, not silicon will rot in sun within year
Jul 07, 2009 | 1995 Jeep Grand Cherokee
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
